Suba_GL_87 Posted July 4, 2011 Share Posted July 4, 2011 recently; i was replace for new head gasket after that i put a parts on the ea82. when i was pour the oil into ea82...there was pretty good running but somehow my ea82 a little hot becuz of without coolant. so, i was pour half of coolant however the motor was shakey/stop became smoke from coolant and i try start it but wont start it like a stuck! what the hell thats coming from, EA82 is very small motor but nonsense!? i need help before i leaving to vacations w my gf. Link to comment Share on other sites More sharing options...
NoahDL88 Posted July 4, 2011 Share Posted July 4, 2011 I'm trying to translate into English You recently replaced your head-gaskets? You added oil, but didn't add coolant? You added half of a jug of coolant to a system that needs about 2 full jugs and the engine stalled because you over heated it and the engine seized? The EA-82 is a small engine but this is nonsense and you need help so you can go on vacation with your girlfriend? It sounds to me, that since you swapped head gaskets and didn't add enough coolant that you seized your engine and probably scuffed the cylinders. I'd do a compression check after you top up the oil and coolant and hope you still have compression and you might not have to do your head-gaskets again. Either way your engine is most likely toast, especially if it won't turn over after it has completely cooled. Link to comment Share on other sites More sharing options...
MilesFox Posted July 4, 2011 Share Posted July 4, 2011 MAybe intake gaskets? Car runs right, with low collant, but too low, it overheats. And when full, it leaks in the intake gasket and hydrolocks the motor Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted July 4, 2011 Author Share Posted July 4, 2011 MilesFox-Intake Manifold Gasket? i was removed old gasket and never used it, but why? NoahDL88- No, i was plan to put 2 new jug coolants for AC cooler...so, i was just pour coolant half during ea82's running but somehow my ea82 just shut down and coolant's smoked from under the exhaust. There is dripping coolant/oil from cycle head block (under the exhaust), too. whats best number of compression test?? maybe i was put too much rubber seal on the thermostat without gasket cause choke from coolant? or no difference? Link to comment Share on other sites More sharing options...
92_rugby_subie Posted July 4, 2011 Share Posted July 4, 2011 You need intake gaskets... Ive heard you can use "other" forms of them, but they are necessary... Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted July 4, 2011 Author Share Posted July 4, 2011 ahh...? thats just only one problem? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 4, 2011 Share Posted July 4, 2011 Coolant flows through the intake manifold. You need gaskets - get them from the dealer. GD Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted July 5, 2011 Author Share Posted July 5, 2011 (edited) ohhh !? no wonder, i was removed and junk it...:-\ im order for it now. thank you. Coolant flows through the intake manifold. You need gaskets - get them from the dealer. GD Edited July 5, 2011 by Turbone Link to comment Share on other sites More sharing options...
86ea82 Posted July 7, 2011 Share Posted July 7, 2011 id put a couple squirts of oil in the spark plug holes and turn it over by hand with a wrench or socket before you use the starter to do it if its locked up Link to comment Share on other sites More sharing options...
heartless Posted July 7, 2011 Share Posted July 7, 2011 id put a couple squirts of oil in the spark plug holes and turn it over by hand with a wrench or socket before you use the starter to do it if its locked up +2 Link to comment Share on other sites More sharing options...
bratman18 Posted July 7, 2011 Share Posted July 7, 2011 Sounds like these guy have it covered! Just out of curiosity, where are you from? Like originally? Link to comment Share on other sites More sharing options...
