Grill compatibility
No - not quite correctly. The mounting is different on the headlight buckets. You would have to use the Loyale headlight buckets.
Really? The only differences in grille mounting that I was aware of was the 3-door vs. sedan/wagon...
Really?
Yeah....
Earlier ones (waffle grill) mount to the buckets and a vertical support in the center of the grill with screws.... Like GD says.
Later ones (loyale style) mount with pins that drop into holes on the trim between the bumper and the grill/headlights, and quick rivets into holes in tabs on the radiator support.
Spencer
