jarl Posted July 8, 2011 Share Posted July 8, 2011 This was a part of a post I made on another forum but the conversation took another direction... so here it is by itself: I need to replace the timing covers on a '95 EJ22, and my first option is to go to a junkyard to get them. Living in Michigan, I expect most engines from that era will have the same issue my engine had (rusted timing cover bolts), so I was wondering if the covers from newer SOHC engines are interchangeable. Experts? Quote Link to comment Share on other sites More sharing options...
lmdew Posted July 8, 2011 Share Posted July 8, 2011 90 - 99 2.2 and the center cover from the 2.5 will all fit. The newer 2 part 2.2 will not work. They are not to expensive from the Dealer. Quote Link to comment Share on other sites More sharing options...
jarl Posted July 9, 2011 Author Share Posted July 9, 2011 Crap. That means I'll have to fight rust... The covers are about $30 each online. One is not too expensive, but given all the parts I need to buy I need to save a few bucks wherever possible Thanks! Quote Link to comment Share on other sites More sharing options...
davebugs Posted July 9, 2011 Share Posted July 9, 2011 Post what parts you need here at USMB. Several of us here have bought and sold these to each other. I've actually got a box of 2.2 and a box of 2.5 covers. Here (in the rust belt) usually atleast the one by the waterpump is rusted and breaks out of the plastic. Also not everyone on this forum is from the rust belt. Quote Link to comment Share on other sites More sharing options...
lmdew Posted July 9, 2011 Share Posted July 9, 2011 I always anti-size the bolts when I put them in even in CO. Quote Link to comment Share on other sites More sharing options...
heartless Posted July 9, 2011 Share Posted July 9, 2011 honestly - i wouldnt even bother with replacing the covers. leaving them off makes it much easier to keep an eye on things, and change when needed. just recently did a reseal on my 1990 EJ22, and while the motor was out, it was de-covered - doesnt even have the back halves anymore. Yes, i was a bit nervous about doing it - i live on a dirt road in north central Wisconsin (yeah rust gets nasty around here too) but it has been a month now and no problems at all. havent been thru a winter this way yet, but i dont really anticipate any problems. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted July 9, 2011 Share Posted July 9, 2011 or maybe zip ties will help you use the ones you have. my 95 has only one factory bolt per side , i think. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2011 Share Posted July 9, 2011 Yes - when you get new rear's - just use black zip-ties instead of the bolts if you live in an area prone to rust. Running without covers is fine too - your engine is non-interferance and the EJ belts are VERY tough. Exceptionally hard to break. GD Quote Link to comment Share on other sites More sharing options...
ShawnW Posted July 9, 2011 Share Posted July 9, 2011 The belt itself might be tough but the idlers and bearings aren't intended to take on the elements directly like that in my opinion. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2011 Share Posted July 9, 2011 The belt itself might be tough but the idlers and bearings aren't intended to take on the elements directly like that in my opinion. I agree to some extent but the bearings are sealed and it's really no different than the bearings on the front of the alternator, the power steering pump, or the AC idler which are all exposed in their "natural" state. The very fact that they are sealed and running in a "dry" (without an oil bath, etc) environment seems to sugest they *are* hardened against the elements - one of which being the rubber "dust" from the belt itself..... I don't think it's a big concern for most folks that aren't going to be fording a river with their rig.... and if you keep the splash gaurds in place under the car most of the elements can't enter easily anyhow. GD Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 15, 2011 Share Posted July 15, 2011 let me guess the bolt where one of the cams snapped and broke the plastic on the cover? Haha I had that problem too.. I just left the cover off (it was the pax side) I'm glad the newer models don't use that setup anymore. I got a little scared because I took the car off-road into some mud and rain+ snow and all.. but it was fine. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 16, 2011 Share Posted July 16, 2011 If you plow through deep damp snow, you can get enough packed into the belt to float it on the pulleys. If you're lucky like me, it happens in front of a drunk white trash lady's house who spends her time screaming threats at you from her porch while you rehang the belt. If you carry a pre-compressed t-belt tensioner with a grenade pin holding it compressed, getting the belt back in line and set is pretty easy. I never had a problem with sticks, stones, or mud, just deep snow. Quote Link to comment Share on other sites More sharing options...
987687 Posted July 16, 2011 Share Posted July 16, 2011 If you plow through deep damp snow, you can get enough packed into the belt to float it on the pulleys. If you're lucky like me, it happens in front of a drunk white trash lady's house who spends her time screaming threats at you from her porch while you rehang the belt. If you carry a pre-compressed t-belt tensioner with a grenade pin holding it compressed, getting the belt back in line and set is pretty easy. I never had a problem with sticks, stones, or mud, just deep snow. Hadn't thought about deep snow... After hearing this I should get covers for my INTERFERENCE***ej.... Quote Link to comment Share on other sites More sharing options...
heartless Posted July 16, 2011 Share Posted July 16, 2011 If you plow through deep damp snow, you can get enough packed into the belt to float it on the pulleys. If you're lucky like me, it happens in front of a drunk white trash lady's house who spends her time screaming threats at you from her porch while you rehang the belt. If you carry a pre-compressed t-belt tensioner with a grenade pin holding it compressed, getting the belt back in line and set is pretty easy. I never had a problem with sticks, stones, or mud, just deep snow. ok, now you have me officially re-thinking the coverless idea - I dont even have to be driving in the crap to get snow under the hood around here - it blows in all on it's own!! (see my avatar) and i frequently have to drive thru deep snow living way out here in the boonies... :-\ Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 16, 2011 Share Posted July 16, 2011 Man and just to think last year in the legacy I was hitting snow banks and in like 7 inches of deep stuff :-| the car had a EJ22 but never thought about the timing belt floating thing.. Only reason I left the cover off was that stupid part that holds the bolt behind the cam snapped and took the plastic with it. Quote Link to comment Share on other sites More sharing options...
jarl Posted July 16, 2011 Author Share Posted July 16, 2011 Uhm... I see a bunch of people racing to the junkyards now... maybe it wasn't that smart to ask in a public forum Quote Link to comment Share on other sites More sharing options...
987687 Posted July 16, 2011 Share Posted July 16, 2011 I've certainly stuffed my car. I had the PS/ALT belt floating like you described, lost ps and my bat light came on... That would suck on an interference motor... Me get timing covers before winter. Quote Link to comment Share on other sites More sharing options...
heartless Posted July 17, 2011 Share Posted July 17, 2011 Uhm... I see a bunch of people racing to the junkyards now... maybe it wasn't that smart to ask in a public forum Nah - no need to go to junk yard for me - kept the covers when we took them off (just in case ) Plus have three parts cars here in the yard! Quote Link to comment Share on other sites More sharing options...
