Lachlan Posted July 9, 2011 Share Posted July 9, 2011 I'm trying to fit a hose barb to an autometer mechanical vacuum gauge (I want to use silicone vacuum hose vice that crappy hard nylon hose w/ compression nut). As far as I can tell, the autometer sensor is 3/8" MPT, with 28 (possibly 27) threads per inch, and I need a 1/8" ID hose barb. Searching on line for brass fittings, it seems impossible to find a 1/8" id hose to 3/8" FPT connector. just about any 1/8" ID hose barb connector I find only goes to a 1/8" FPT. Does anyone have super secret information on a brass fitting site that has what I'm looking for? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2011 Share Posted July 9, 2011 You need a 1/8" x 3/8" NPT bushing. GD Link to comment Share on other sites More sharing options...
Lachlan Posted July 9, 2011 Author Share Posted July 9, 2011 GeneralDisorder said: You need a 1/8" x 3/8" NPT bushing. GD The problem with that is that it greatly increases the length of the hardware out the back. I'd rather have all-in-one. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2011 Share Posted July 9, 2011 (edited) If you get the right bushing it should only increase it by 1/8" or so - and you can file down the hex end of the bushing to shorten it.... then you can cut off a bit of the end of the hose barb.... you can make it work. I doubt you will find a 3/8" barb fitting. They usually skip that size. Why doesn't autometer include one or have one you can buy that's plastic or something? Another idea - you could make a flush-mount bushing with a bit of brass stock, some drilling, tapping, and threading..... wouldn't be too hard. Just do the ID first - thread the brass 1/8" barb fitting into it, then cut the OD threads with a die. GD Edited July 9, 2011 by GeneralDisorder Link to comment Share on other sites More sharing options...
Lachlan Posted July 23, 2011 Author Share Posted July 23, 2011 Thanks. Yeah, I could fit something together. I was just hoping someone might have seen the miracle piece already assembled. Link to comment Share on other sites More sharing options...
Yo'J Posted July 23, 2011 Share Posted July 23, 2011 Call Fittings Inc. out of seattle. They dont up charge either. I'm amazed at their selection. Link to comment Share on other sites More sharing options...
