eppoh Posted July 9, 2011 Share Posted July 9, 2011 Still working on this project someone else took apart. I need help identifying a vacuum line/tap. On the back side of the #3 cylinder intake spider there is a very small ( maybe 5mm) intake tap. I cannot figure out what line goes there and to what. It is the 97 2.2 Lego Anyone know? Can't find a picture and the diagram on the hood and in the manual is not much help. This project is getting me down. Just found tonight all the AC compressor mount bolts are missing too. Link to comment Share on other sites More sharing options...
markjw Posted July 9, 2011 Share Posted July 9, 2011 (edited) If it's anything like my '92 2.2 then it leads into the aft end of the fuel rail by way of a metal tube. It starts off rubber hose, then about 5 inch's of the metal tube, then ends in rubber hose terminating at what looks like a pressure regulator. Edited July 9, 2011 by markjw Link to comment Share on other sites More sharing options...
eppoh Posted July 9, 2011 Author Share Posted July 9, 2011 Thanks, I have a feeling my son left that metal tube off when he installed the intake. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 9, 2011 Share Posted July 9, 2011 What exactly is this "project" and why would the metal hard lines have been removed from the intake?!? I've never taken those off. Is the engine original to the car? There were about three or four different vacuum routings over the years on the 2nd gen EJ's..... if the engine came from a different car it might not match up to anything. The trick is to follow the lines and find out what they go to and make sure everything has the vacuum signal that it needs.... GD Link to comment Share on other sites More sharing options...
eppoh Posted July 10, 2011 Author Share Posted July 10, 2011 To make a long story short. Someone pulled the engine to swap it, since this one had bent valves. The engine he brought was no good, so removed the heads to have them repaired. He quit, and left - everything laying around the shop. My son ( it's his car) decided to remove the intake and paint it red. That is when the tube was removed. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 10, 2011 Share Posted July 10, 2011 If you can post a picture I can tell you where it should go. GD Link to comment Share on other sites More sharing options...
eppoh Posted July 10, 2011 Author Share Posted July 10, 2011 Will do that tomorrow, after I fix the rabbit hutch. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 10, 2011 Share Posted July 10, 2011 Just run a rubber hose straight down there to the fuel pressure regulator. That's how it was done on the older cars. Link to comment Share on other sites More sharing options...
eppoh Posted July 10, 2011 Author Share Posted July 10, 2011 Okay, found the place to connect to hose to the manifold and the regulator, However , I found this metal pipe on the cart, that I have no idea where it goes. It still has some rubber vacuum line on it from when it was removed,. Link to comment Share on other sites More sharing options...
markjw Posted July 10, 2011 Share Posted July 10, 2011 That first pic I posted is of my '92, 2.2 in my wagon. All the others are of this EGR, 2.2 manifold I picked up somewhere. Pretty dirty, but mostly complete. Maybe some of these pic's will help. Link to comment Share on other sites More sharing options...
eppoh Posted July 10, 2011 Author Share Posted July 10, 2011 Thanks, I'll check, but I don't think this is one of those lines on your manifold. My EGr is hooked up, the fuel press regulator is hooked up and the engine runs (not well without the airbox on it.) Since this line is painted black, I think it has something to do with the air box, filter system. Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 11, 2011 Share Posted July 11, 2011 Probably one of the evap system lines. I've never seen the hard line with the T in it like that though, so I can only guess where it goes. I'm pretty sure it has nothing to do with the airbox though. Is this engine original to the car? You can look on the bottom of the hood there is a sticker/label with the routing diagram for all of the vacuum hoses. Link to comment Share on other sites More sharing options...
eppoh Posted July 11, 2011 Author Share Posted July 11, 2011 Original engine. I may get a better idea when the air box is on. Hoping someone would recognize it. Link to comment Share on other sites More sharing options...
eppoh Posted July 11, 2011 Author Share Posted July 11, 2011 Looking inside the tube, it has a white powdery build up in it. Smells a bit like solvent. Looked at a friends RHD 97 and cannot find it on theirs. Link to comment Share on other sites More sharing options...
