Uberoo Posted July 10, 2011 Share Posted July 10, 2011 I have a stripped EJ22 harness and computer sitting in my garage,but its been so long since I stripped it that I forgot what year range it will work for.I think it is an early EJ22 harness because it only has 2 connectors for the engine on the left side instead of the two larger connectors + one small connector on the latter ones. so what year range legacy uses the two connector setup on the left side? Thanks in advance. Link to comment Share on other sites More sharing options...
Gloyale Posted July 11, 2011 Share Posted July 11, 2011 I think it is an early EJ22 harness because it only has 2 connectors for the engine on the left side instead of the two larger connectors + one small connector on the latter ones. You got it backwards. 90-91 has 2 large and 1 smaller connector at the engine. 92-94 has just 2 large connectors. 95-99 has 3 large connectors that mount near the rear of the engine, passenger side. sounds like you've got a 92-94 harness. Link to comment Share on other sites More sharing options...
Uberoo Posted July 12, 2011 Author Share Posted July 12, 2011 Oh ok thanks. Link to comment Share on other sites More sharing options...
