bratman18 Posted July 11, 2011 Share Posted July 11, 2011 How do you remove the stubs from the rear diff of a 91 Legacy turbo? They do not have the bolts through the center of them like the older diffs. So do the just pop off like the ones in the tranny? Thanks Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 11, 2011 Share Posted July 11, 2011 That's a viscous LSD (VLSD) diff - They either have internal snap rings or e-clips. Remove the back cover and inspect. GD Link to comment Share on other sites More sharing options...
bratman18 Posted July 14, 2011 Author Share Posted July 14, 2011 That's a viscous LSD (VLSD) diff - They either have internal snap rings or e-clips. Remove the back cover and inspect. GD I haven't had internet so I wasn't able to respond. Yeah I know it's a VLSD. So either way, there is a way to remove the stubs? I want to remove the stubs and use the newer style male ended axles. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 14, 2011 Share Posted July 14, 2011 I want to remove the stubs and use the newer style male ended axles. Actually I just went though this in my garage - unfortunately what you want to do will be impossible. The stubs are c-cliped in and while they will pry right out of the diff - they are not the same for right vs. left!! The passenger side is a normal stub but the driver's side stub has an extra, smaller diamter, splined section on the end of it that engages the LSD components - none of the newer axle's have this additional "early LSD" right side stub on the end of them - thus you could install them but the LSD would not function and the c-clip groove would not be in the correct place to snap into the diff - leading to the axle floating out of the diff and causing gear oil leakage. GD Link to comment Share on other sites More sharing options...
bratman18 Posted July 14, 2011 Author Share Posted July 14, 2011 Well that really sucks. Thanks for the info GD. Link to comment Share on other sites More sharing options...
MilesFox Posted July 14, 2011 Share Posted July 14, 2011 I have a set of rear axles for vlsd 91 legacy. The inner cups should fit on another axle, i suppose. Let me know if these are something you need. Link to comment Share on other sites More sharing options...
ShawnW Posted July 15, 2011 Share Posted July 15, 2011 If you are just trying to put the diff in an impreza, use the legacy turbo axles in the Impreza. Link to comment Share on other sites More sharing options...
bratman18 Posted July 15, 2011 Author Share Posted July 15, 2011 Yeah I have this stuff all installed in my Forester XT actually. I am having serious issues with the axles. It seems like they are trying to pop out of their cups on the outer joints. It cause insane noise and vibration. I should add that they are just about completely horizontal with little or know angle because the Forester is lowered. I figured they would be better this way, but they are not. I wanted to upgrade to the newer style axles, but I guess I can't. Link to comment Share on other sites More sharing options...
987687 Posted July 15, 2011 Share Posted July 15, 2011 You could do hybrid axles. Use a newer axle and the older style inner joint. Link to comment Share on other sites More sharing options...
bratman18 Posted July 18, 2011 Author Share Posted July 18, 2011 So GD, do you have any knowledge if the SVX axles would click into the SS rear diff? Sounds like they have the same VLSD inside of them. Seems like the SS came with stubs to accommodate the "different" insides it has, and the SVX used male ended axles that were shaped a little different to accommodate this. So do you think if you popped the stubs out, that the SVX axles would slide in, and function/seal? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 18, 2011 Share Posted July 18, 2011 I really don't know - I've never owned an SVX or wrenched on that portion of one..... Ask Turbone - he might know. GD Link to comment Share on other sites More sharing options...
rally_wrx Posted November 15, 2011 Share Posted November 15, 2011 (edited) Actually I just went though this in my garage - unfortunately what you want to do will be impossible. The stubs are c-cliped in and while they will pry right out of the diff - they are not the same for right vs. left!! The passenger side is a normal stub but the driver's side stub has an extra, smaller diamter, splined section on the end of it that engages the LSD components - none of the newer axle's have this additional "early LSD" right side stub on the end of them - thus you could install them but the LSD would not function and the c-clip groove would not be in the correct place to snap into the diff - leading to the axle floating out of the diff and causing gear oil leakage. GD What about axle stubs like these? Did the 'normal stub' you looked at resemble a male axle end? I'm trying to do the same thing as the OP (put male axle ends into the above pictured LSD) but it looks like I should be able to because the axle stubs I have are identical from left to right? Edited November 15, 2011 by rally_wrx Link to comment Share on other sites More sharing options...
