common spot for oil leak
Valve covers, and the oil pan gasket. Same as EA81's actually.... do em up with high temp RTV, and they won't leak..... for a while.
As for the drain plug - get a new metal crush gasket every few times you change the oil. They are cheap, and I usually buy 10 or 20 at a time....
