ea82 thoughts on compression test see latest post question on distr wiring colors...
looks decent, you're almost within 10% which is o.k.. i'd do it a second time, maybe in reverse order or with a different gauge and see what you get due to the variation.
full current available (battery fully charged)?
throttle propped open to allow unrestricted air flow?
were all plugs removed when doing it for each cylinder or did you remove them as you went?
usually doesn't make much difference but that generally keeps things efficient and comparable.
all plugs removed.
snap-on guage
throttle propped some
battery, probably could charge it up again.
I think the problem on this car is something in distributor. runs pretty lousy, plug wire for cylinder 3 when on the cap, makes a "pop, pop, pop" sound near the distributor. unplug #3, and no pop pop pop..
timing is on.
bought the car in this condition.
wont talk about how the plugs looked, not putting these back in it.
Edited by bheinen74
compression isn't causing that. bad sound and plugs makes it sound like it could be an easy fix:banana:
cap/rotor is probably warn or hosed.
i even had a brand new XT6 rotor fail on me in less than a year once. pulled the cap and there it was, all shredded up for no reason. perfectly running car, distributor, no cross threaded bolt or anything - just blew up one day while driving and ran great with once fixed.
Okay more digging found:
distributor connector wiring connector:
harness side - distr side
black . . black
red . . red
GRN . . WHITE
WHITE . . GRN
thats doesnt seem right with how i know sub wiring to be...anyone got one of these pos cars to see if yours is that way?
Edited by bheinen74
installed new NGK plugs, got second distributor, installed that dizzy, still same issue, pop-pop=pop when the plug wire to cylinder 3 is on the cap. so no change.
just ordered a new cap....
if that doesnt do it, then only thing i can think of is plug wires.
anymore thoughts. the red turd still awaits a good running day.
i only sweat a little putting the plugs and dizzy in, temp is 95 heat index 110, likely to have this another 6 days of temps.
oh here is the red turd
DSCF0017.jpg?t=1311028853
DSCF0016.jpg?t=1311028829
Edited by bheinen74
I've had vehicles do the snap sound before and been able to see the high tension leak in the dark. Try looking with it running at night. And I want to thank you for sending us that heat. It was beutifull last weekend. Mid 80's with low humidity. This weekend 101 with high humidity. And I need to get the drive train back in the daughters car. YeeHaa
