Braking vibration after replacing CV axles
a bolt isn't properly tightened - axle nut or wheel nut...or any others you may have removed to do this.
or one/both of the axles are bad.
if you still have the old axles your best bet for long term reliability is to have them rebooted and avoid the after market axles, they are notoriously problematic. if they were clicking then they're probably not worth keeping but if the boots were just torn, save the origianals. not just out of the box either - long term reliability isn't good either.
i buy used subaru axles and reboot them. i get them for $25-$33 each and reboot them. extra effort but it's worth the time saved from dealing with the endless aftermarket issues. i've seen it all - vibration, exploding to pieces, leaking, noises.....it can happen on day one, 100, or 10,000. subaru axles are beefy and do not fail unless you abuse them.
MWE is the only other good option for axles.
  jimrichard said:
I used aftermarket axles from AUTOZONE. Accelerates smoothly and no more clicking when turning. Just the shakes when braking. I will see if something is not tightened enough. What is the torquing for the axle nuts ?
I use AZ axles. Occasionally, I will get one with a worn bearing that causes some shakes, but not that often. AZ guarantee is good on replacement, so it is just the labor to R & R. Okay, if working on your own car, but not something you would want to put on a customers car if you are in the repair biz.
really tight! rare to use an actual torque wrench but 140 will do it. i go with the 2 foot pipe and put some stank in it ft-pounds.
a quick google/search here gives:
http://www.ultimatesubaru.org/forum/showthread.php?t=87075
http://www.ultimatesubaru.org/forum/showthread.php?t=114416
http://www.ultimatesubaru.org/forum/showthread.php?t=109532
