Bdubya Posted July 13, 2011 Share Posted July 13, 2011 Hello everyone! I am hoping someone can help, I have a 90' Subaru Loyale with a saggy rear bumper. I crawled around under the car to find how it was attached all I saw was screws that seem to just connect the bumper to the bumper cover. I searched Hi and low for a repair manual, only found for engin and electrical. Could someone please tell me how to detach / reinstall bumper? Many Thanks, Brian Link to comment Share on other sites More sharing options...
TheLoyale Posted July 13, 2011 Share Posted July 13, 2011 If its a wagon, open the rear gate, and then lift up that little "Smugglers hatch" in the floor, you will see 4 rubber plugs (2 per side) there is a 14mm bolt behind each of those plugs. Remove them, and the entire bumper will pull aay from the car. If its a Sedan, you will need to pop off the interior inside the trunk, then you will see the 4 14mm nuts which hold it onto the rear roll pan. -Tom Link to comment Share on other sites More sharing options...
Bdubya Posted July 14, 2011 Author Share Posted July 14, 2011 Thanks Mr. Loyale for that awesome info, I would have never guest that was under the plugs. Are these the only bolts that hold up the bumper? It seems like there should be a bracket of some sort under the tail lights, there are 2 holes in the bumper... Ps it is a Wagon.. Thanks again! Link to comment Share on other sites More sharing options...
heartless Posted July 14, 2011 Share Posted July 14, 2011 nope, thats it, just those 4 bolts. the "bracket" is in integral part of the bumper itself - you are unbolting the bracket from the subframe of the car. Link to comment Share on other sites More sharing options...
TheLoyale Posted July 15, 2011 Share Posted July 15, 2011 nope, thats it, just those 4 bolts. the "bracket" is in integral part of the bumper itself - you are unbolting the bracket from the subframe of the car. +1 to that! No problem, thats what this place is for Take care! -Tom Link to comment Share on other sites More sharing options...
