So...the last clutch I put in was on an old style GL/Loyale...years ago
Whats different about the hydraulic clutch?
I have to do a 2003 impreza RS....ugh...
So what parts do I need
Is the installation procedure much different than the older models?
disc, P plate, TO bearing, what else?
Pilot bearing? When would you have the flywheel resurfaced or not?
Oh...I remember there used to be an "0" stamped in on the flywheel? and a mark on the new pressure plate and somethinfg about keeping the marks 120 degrees apart for balance reasons???
Keep in mind that I am selling this as soon as it is done...so the less money spent the better....thus, whats a good kit at a low cost? Anyone recommend something they have used and where bought?
Thanks gents!
thanks durania...great write up
I assume the 99 uses the hydraulic clutch...
So...a few unanswered questions:
There is no balancing issues when mounting the P plate?
Anyone want to chime in on the lower cost clutches(source/brand)? Perhaps something someone has used in the past?
No.
You need an Exedy KSB04. Amazon has the best price. About $145 - you aren't going to find a complete kit for much less and if you really cheap out you may regret it's performance.
Have the flywheel surfaced - about $25 to $30 at any machine shop - a good shop can do it while you wait.
No.
Thank you General...!
