tallwelder81 Posted July 26, 2011 Share Posted July 26, 2011 i just want my brat up a hair or two. can i use different struts? springs? anything like that just to gain an inch or so? Link to comment Share on other sites More sharing options...
Turbone Posted July 26, 2011 Share Posted July 26, 2011 Bigger tires Link to comment Share on other sites More sharing options...
tallwelder81 Posted July 26, 2011 Author Share Posted July 26, 2011 i thought i had one read something on here about taller springs? taller struts? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 26, 2011 Share Posted July 26, 2011 (edited) Nope - not without making them yourself. None of the stock springs or struts will lift the front. The rear is easy - you just clock the torsion bar down a spline or two - its a "suspension" lift and can be adjusted with the adjuster bolt and how many splines you move the trailing arms... But you better also drop the diff if you don't want to break axles and you will have to go to the Rancho shocks. The front must be lifted with blocks on the stut towers, or strut tube extensions.... etc. GD Edited July 26, 2011 by GeneralDisorder Link to comment Share on other sites More sharing options...
Mykeys Toy Posted July 26, 2011 Share Posted July 26, 2011 There is a post from OneEye in the offroad section about the tube extensions to extend the strut from the top. It looks fairly easy and thats what he wheels with so strength isn't an issue. Link to comment Share on other sites More sharing options...
bheinen74 Posted July 26, 2011 Share Posted July 26, 2011 the front struts have built in adjuster nuts...crank them up the rear has a bolt to adjust the torsion bar force. look in the manual in the glovebox top... Link to comment Share on other sites More sharing options...
Qman Posted July 26, 2011 Share Posted July 26, 2011 The torsion bar reclock when done on my old Hatch was good for about 1-1 1/2" lift. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 26, 2011 Share Posted July 26, 2011 I suppose it depends on how many splines you skip. I remember a local guy here a few years ago used that method on his wagon and it was slightly higher than the 3" blocks he had in the front. Perhaps he skipped two splines on the reclock. I only saw the end result - I wasn't present for the actual procedure. GD Link to comment Share on other sites More sharing options...
Qman Posted July 26, 2011 Share Posted July 26, 2011 I guess that is the difference between doing it and seeing it! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 26, 2011 Share Posted July 26, 2011 Yes - you are correct. I was merely informing the OP that it's possible - I revised my first post to reflect the vague nature of my knowledge of how high it would go should he do it. GD Link to comment Share on other sites More sharing options...
renob123 Posted July 26, 2011 Share Posted July 26, 2011 Using RX springs on the front will lift it up a bit. Jacob Link to comment Share on other sites More sharing options...
tallwelder81 Posted July 27, 2011 Author Share Posted July 27, 2011 now thats what im looking for!! do those options hurt suspension travel or handling noticeably? i dont mean the higher center of gravity aspect. i mean, you know, camber, axle angles, etc.... Link to comment Share on other sites More sharing options...
Qman Posted July 27, 2011 Share Posted July 27, 2011 tallwelder81 said: now thats what im looking for!! do those options hurt suspension travel or handling noticeably? i dont mean the higher center of gravity aspect. i mean, you know, camber, axle angles, etc.... Yes... to all! Link to comment Share on other sites More sharing options...
Numbchux Posted July 28, 2011 Share Posted July 28, 2011 GeneralDisorder said: I suppose it depends on how many splines you skip. I remember a local guy here a few years ago used that method on his wagon and it was slightly higher than the 3" blocks he had in the front. Perhaps he skipped two splines on the reclock. I only saw the end result - I wasn't present for the actual procedure. GD My brat is reclocked. Not sure how many we skipped, but it was a few. 4" strut extensions in the front, and the eyeball says the back is a bit more. Definitely wasn't just 1 spline though. It's not a small project. Here in the rust belt (this body has over 200k on it, AFAIK all in the midwest), we had a heck of a time getting them out. Also, the rear alignment is definitely not right now..... Link to comment Share on other sites More sharing options...
