yes or no: I use unmodified TURBO EA axles when using a EJ trans and stock EA hubs.
biggreen96
  • 1 month later...
To add to the confusion that you're trying to clear up, the front wheel drive EJ gearboxes (not AWD) are still 23 inch spline.
But why you'd drop in the EJ and a front wheel drive gearbox is beyond me!
Cheers
Bennie
do not know if that is correct, as people on bbslegacy central sometimes go replace the fronts on the turbo cars with axles from FWD car, cause the shafts are beefier on the fwd model, think splines all same.
All EJ autos are 4EAT's, which means 25 spline. It's the early FWD 5spds in Legacies and Imprezas up to 95 that are 23 spline.
