Phoenix_Rayn Posted July 29, 2011 Share Posted July 29, 2011 ok so i have no spark on three of four cylinders its not my coil pack i do have error codes for throttle position sensor and purge control solenoid valve. i have tried to look it up and had no luck my haynes manual isnt being very helpfull either does anyone have any idea what my problem could be and how to fix it i do a lot of the work myself and hope i can get it figured out soon. Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 30, 2011 Share Posted July 30, 2011 Check the crank sensor waveform signal and make sure it is ok. You are going to need a scope to do that. If you haven't made sure the plug wires are ok do that also. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 30, 2011 Share Posted July 30, 2011 Yeah - try a used set of crank/cam sensors and if you still have issues try a used ignitor. GD Quote Link to comment Share on other sites More sharing options...
Phoenix_Rayn Posted July 30, 2011 Author Share Posted July 30, 2011 thats kinda what i thought wanted some back up on that anyone know if the throttle position sensor affects the spark at all ive heard yes and no on that Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 31, 2011 Share Posted July 31, 2011 (edited) The TPS sensor has no control of the ignition system. It indirectly controls the pulse width signal to the injectors through the ECU along with the throttle body position info. Edited July 31, 2011 by Cougar Quote Link to comment Share on other sites More sharing options...
Phoenix_Rayn Posted August 1, 2011 Author Share Posted August 1, 2011 ok thank you i got a cam and crank sensor gonna post tonight to let people interested know of my findings. Quote Link to comment Share on other sites More sharing options...
Phoenix_Rayn Posted August 1, 2011 Author Share Posted August 1, 2011 ok i feel really dumb i replace TPS Cam and Crank sensor ignighter and purge control solenoid valve. I just found out i overlooked a blown fuse and now my battery is dead and engine flooded so i have to wait till the morning to see if the replaced fuse fixed my problem it was a 15 fuse and i think it was the one for the ignition so hopefully it works in the morning but if it doesnt does any one have anymore suggestions for me to try???? i will be at a loss and very upset if i am FUBAR:-\ Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 1, 2011 Share Posted August 1, 2011 (edited) You stated earlier that the ignition was working on three of the four cylinders. If that is correct then the blown fuse was not the problem, at least at that time. Something else is causing the problem with the spark to the fourth cylinder. If the fuse has anything to do with the ignition system then none of the plugs will be firing if it is blown. The most logical cause of the spark problem to the plug is a bad spark plug or the wire to it. I assume you have already eliminated those possibilities by swapping them out. Edited August 1, 2011 by Cougar Quote Link to comment Share on other sites More sharing options...
