98 outback sport keyless entry
I recently bought my outback and I'm going through seeing what all works when I was at he guys house buying the car the key less doors worked granted I had to stand pretty close to the car but it still worked I assumed the battery was old so I swapped it out now its not working at all. I tested the new battery was 12v so its good.
I found the original parer showing how to reset the key less fob. It said to open the drivers door turn key to "on" position and hold the program button for 15 seconds then the doors should lock/unlock three times then I press the lock button on the key fob and release the program button and it should all be rest. Problem is when holding the program button it never does its lock/unlock three times thing, am i missing a step or possibly a fuse somewhere? Thanks
98 Impreza Outback sport wagon
is the key in the ON position? not just the the first click where the radio comes on but the next click where the AC / heater fan will blow and the headlights are on and all of the dash lights are on. that was my mistake on my first try.
did you replace the car battery or the fob battery?
does the fob ''light'' blink when you press the button? if it has a light.
is the battery in the right way?
I replaced the fob battery the cars battery was disconected though for a short time I was wondering if it reset the cars key less entery system. I had the key turned to the "on position the dash lights came on and the ignition says "on" and I dont see a light on my key fob its just the two lock/unlock buttons.
Well after several trys still not getting the key fob to work not a huge deal but this is my first car with a key fob so I was kinda excited for that when I bought it. Oh well maybe ill figure it out someday.
