guyph_01 Posted August 3, 2011 Share Posted August 3, 2011 Hi guys, I have searched but didn't find anything yet. Would anyone know or has done a write up on converting the loyal head lights from single to twin lights? I'm about to attempt this any a write up or any help would be greatly appreciated. Thx Guy Link to comment Share on other sites More sharing options...
el_freddo Posted August 3, 2011 Share Posted August 3, 2011 Hehehe... I've had the same thoughts about this light setup guyph! Did you use a set from the US or a set off an MY over here?? Wiring it wouldn't be hard mate - a set of relays to trigger high or low beam referenced from the original wiring would be the go. You should be able to work that out and if no ask one of the fellas about "the relay headlight upgrade" and just add a 3rd relay to each side for the high beam on the extra light Cheers Bennie Link to comment Share on other sites More sharing options...
bigjimd Posted August 3, 2011 Share Posted August 3, 2011 This may help with the wiring, found it last night looking for a post on good relays to use. http://www.danielsternlighting.com/tech/relays/relays.html Link to comment Share on other sites More sharing options...
guyph_01 Posted August 3, 2011 Author Share Posted August 3, 2011 Thx for the help:) Link to comment Share on other sites More sharing options...
tractor pole Posted August 4, 2011 Share Posted August 4, 2011 I will be doing this soon on my 91 loyale I already have all the parts. I will try and do a write up when I do it. Link to comment Share on other sites More sharing options...
man on the moon Posted August 4, 2011 Share Posted August 4, 2011 Be prepared to do some cutting and welding, if I understand things correctly. I inquired about this very thing to a local Subaru specialist/mechanic guy here in Denver a few months ago. I wanted to knock out the second light and put in a set of offroad lights in the cavity, but same difference. Anyway, he told me Subaru changed the shape and size of the headlight body between the GL/DL, and Loyale...I haven't messed around at the junkyard to see if they will swap, but just eyeballing it I have the gut feeling he's right. Worth keeping in mind/checking out before you get too far into it. And if it works I will be your biggest fan , and will be right behind you to do it. Link to comment Share on other sites More sharing options...
guyph_01 Posted August 6, 2011 Author Share Posted August 6, 2011 Only one way to find out:D Link to comment Share on other sites More sharing options...
Ioku Posted August 19, 2011 Share Posted August 19, 2011 I plan on doing this too if I finish first I'll post up some info and pics. Link to comment Share on other sites More sharing options...
guyph_01 Posted October 12, 2011 Author Share Posted October 12, 2011 Well its was all bolt on for me. as easy as that. Now i need to figure out the wiring side. Did you guys have any luck? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 13, 2011 Share Posted October 13, 2011 if you Click on my Avatar, You'll find a List of my Writeups, including this one that Might help here: http://www.ultimatesubaru.org/forum/showpost.php?p=980714&postcount=7 Kind Regards. Link to comment Share on other sites More sharing options...
