Hocrest Posted August 5, 2011 Share Posted August 5, 2011 Quick question. Will alloy 15" wheels fit on a 2000 Leg GT? Steel 15" wheels? And I guess I'm correct that 14's won't fit at all? Quote Link to comment Share on other sites More sharing options...
ocei77 Posted August 5, 2011 Share Posted August 5, 2011 If they are Subaru 15's yes in both cases. 14's won't clear calipers. Subaru uses a high offset (52-55mm), so depending on rim size 48 up will fit, without any issues. O. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 5, 2011 Share Posted August 5, 2011 what he said though i wasn't sure about the steelies. Quote Link to comment Share on other sites More sharing options...
Hocrest Posted August 5, 2011 Author Share Posted August 5, 2011 It has 16" stock, I'm just curious which of the set's of wheels I have around would fit if needed?? My grandson's dad is buying this car, it needs tires and I'm just trying to think in advance if anything I have around here will allow him to postpone $400 in tires for a few weeks. Unfortunately I think everything I have that's usable right now is on 14" rims... edit and O., all my sets are Subaru rims, so I'm not worried about the offset. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted August 6, 2011 Share Posted August 6, 2011 It has 16" stock, I'm just curious which of the set's of wheels I have around would fit if needed?? My grandson's dad is buying this car, it needs tires and I'm just trying to think in advance if anything I have around here will allow him to postpone $400 in tires for a few weeks. Unfortunately I think everything I have that's usable right now is on 14" rims... edit and O., all my sets are Subaru rims, so I'm not worried about the offset. It prolly isn't much work to try to install smaller wheel in place of your 16", but I am thinking the caliper will not likely let the smaller wheel mount up as others have said. I think you will have to spring now for the new tires, which is not what you want to hear. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 6, 2011 Share Posted August 6, 2011 It prolly isn't much work to try to install smaller wheel in place of your 16", but I am thinking the caliper will not likely let the smaller the larger rotors don't come on the GT's until 2002 or 2003, so he can use smaller wheels, though no subaru 14's will work. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted August 6, 2011 Share Posted August 6, 2011 (edited) GT has 10.7" F and 11.3"R rotors. 16" wheels have @1/2 to 3/4" of clearance. 15" will have less. Once he buys the car, try one. I would be shocked and a few other things if 14" fit. Checking cars 101, the last Suby that offered 14" wheels had a rotor size of 10.5". O. Edited August 6, 2011 by ocei77 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 6, 2011 Share Posted August 6, 2011 I would be shocked and a few other things if 14" fit.they do *not* clear the front calipers. i'm not guessing or suggesting, i've actually done it. Quote Link to comment Share on other sites More sharing options...
Hocrest Posted August 6, 2011 Author Share Posted August 6, 2011 they do *not* clear the front calipers. i'm not guessing or suggesting, i've actually done it. If they don't clear, how have you done it?? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 6, 2011 Share Posted August 6, 2011 If they don't clear, how have you done it?? i meant what i said, good question. you can partially bolt one lug nut on and the wheel is all cock-eyed. i do it to keep the hub partially shielded and off the ground of parts cars and 14" rims out of my storage space. Quote Link to comment Share on other sites More sharing options...
