kanurys Posted August 5, 2011 Share Posted August 5, 2011 Has anyone replaced their brake lights with LED lights like ones on ebay? Are they as bright as the conventional light bulbs? What has your experience been? Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted August 5, 2011 Share Posted August 5, 2011 I was recommended to check out "superbrightleds.com" http://www.ultimatesubaru.org/forum/showthread.php?t=124088 Theres some bashing on me for wanting tinted taillights But my tail lights arent even that dark so although I may get those bulbs soon, its not necessary for me.. They seem to have really good prices for what youre getting Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 5, 2011 Share Posted August 5, 2011 don't assume that everything on superbrightleds are actually superbright. I bought the cheapest ones for my celica, and they were not bright enough for primary use. customer service was great, and I was able to return them. I'd buy again, but don't cheap out on your marker lights. I recently bought LED dome lights for my 4runner from autolumination.com. They're site is a little harder to navigate, but a great selection and good prices. and for custom applications, check out oznium.com Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 5, 2011 Share Posted August 5, 2011 I did a custom dome light and map light each having their own LED driver's.. the dome light it's self is more then bright enough for the whole car I'm kicking myself still I did not take my rear tail lights off my Legacy they were JDM taillights. I was going to do custom rear turn signals but having issues trying to figure out how to do the dual brightness with the headlights on since the driver will always want to do the same voltage output. Quote Link to comment Share on other sites More sharing options...
kanurys Posted August 5, 2011 Author Share Posted August 5, 2011 you could build a pwm circuit to dim them. Just search around online. Thanks for the responses. I'd like to use them for the tail/brake corner lights and the trunk mounted brake light in my 87 GL. I have a voltage meter in the dash and with my headlights on, radiator fan and cabin fan running the voltage drops below 12v when I step on the brake. I'll also be doing the maxima alternator mod, but LED conversions are also really cool . I guess my question really is how bright are specific bulb conversions and will they be adequate to be safe even in sunlight? I've seen really bright LED lights on fancy busses and bmw's, etc... so I'm sure they're out there. What is available to us that would just insert where the bulb used to be? Quote Link to comment Share on other sites More sharing options...
kanurys Posted August 5, 2011 Author Share Posted August 5, 2011 (edited) Those sites are good links. I think I'd be in the hole about $60-80 for just brake lights. What color would you guys go with? Cool white or warm white? other? Edited August 5, 2011 by kanurys Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 5, 2011 Share Posted August 5, 2011 http://www.v-leds.com/Exterior-LED-Bulbs/Turn-Signal-LED/Red-LED/V-LEDS-RED-54-M-SMT-TAILBRAKE-p9596930-1-2.html Oznium rocks too, I used them for the front flashers. Quote Link to comment Share on other sites More sharing options...
kanurys Posted August 5, 2011 Author Share Posted August 5, 2011 (edited) right on. What about wiring? Are resistors built into these bulbs or do I need to add one in series with each bulb? And, should I get red leds to put in my red lens tail lamps or white leds? Edited August 5, 2011 by kanurys Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 5, 2011 Share Posted August 5, 2011 Those sites are good links. I think I'd be in the hole about $60-80 for just brake lights. What color would you guys go with? Cool white or warm white? other? just doing my inside LED lighting was about $65-70.. Quote Link to comment Share on other sites More sharing options...
Turbone Posted August 6, 2011 Share Posted August 6, 2011 right on. What about wiring? Are resistors built into these bulbs or do I need to add one in series with each bulb? And, should I get red leds to put in my red lens tail lamps or white leds? It depends. With the LED's in my front signals they blink fast because of the different wattage. I could put a resistor in, but the quicker flashing doesnt bother me. I would use the red bulbs for the brakes and white for signals. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted August 6, 2011 Share Posted August 6, 2011 They have the resistor required to make the LED work, but not to make the flasher work. There are resistors to mimic the load of a traditional light so your flasher works properly, but that would defeat the purpose of running LEDs (lower draw). Just get a flasher designed for LEDs Quote Link to comment Share on other sites More sharing options...
Uberoo Posted August 6, 2011 Share Posted August 6, 2011 I have seen people run a small light in parallel with LED turn signals to get the right speed. on my offroader I am thinking about replacing the stock taillights with a set of LED trailer lights mounted higher and further inboard because I keep breaking the housings... Quote Link to comment Share on other sites More sharing options...
kanurys Posted August 6, 2011 Author Share Posted August 6, 2011 Thanks guys. With turn signals, I'm not as concerned with saving power, but the higher power using brake lights and marker lights would be a good idea. I'll look into a flasher for leds anyways. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted August 6, 2011 Share Posted August 6, 2011 (edited) at superbrightleds make sure to get the 18 LED or 45 LED tower lights.They have lots of radial mounted LED's so the light reflects and fills up the housing with light.otherwise LED's tend to create a "hot spot" of light directly in front of the LED.. Edited August 6, 2011 by Uberoo Quote Link to comment Share on other sites More sharing options...
kanurys Posted August 8, 2011 Author Share Posted August 8, 2011 Good call. I've seen that on some raspy sounding hondas. I'm going for a nice full light fill. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 8, 2011 Share Posted August 8, 2011 I Run the Front Marker Lights on my Subie with Those SuperBright Leds since Years Ago, They Work Just Great since Then up today. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 9, 2011 Share Posted August 9, 2011 I'm in the process of making LED tailights for my XT6 and have figured out how to make them, and to make them sequential like the new Mustangs:banana: Quote Link to comment Share on other sites More sharing options...
eulogious Posted August 9, 2011 Share Posted August 9, 2011 I'm in the process of making LED tailights for my XT6 and have figured out how to make them, and to make them sequential like the new Mustangs:banana: Now this is cool. You will show everyone how to do this right That's killer man, can't wait to see it! If you want to find out what resistor to use to make the lights not flash fast, just measure the resistance of the light that is currently in the socket. All lights have some resistance, and this will tell you about what size resistor to get, well at least get you in the ball park. Quote Link to comment Share on other sites More sharing options...
Cyfun Posted August 10, 2011 Share Posted August 10, 2011 I'm in the process of making LED tailights for my XT6 and have figured out how to make them, and to make them sequential like the new Mustangs:banana: Holy balls, you've gotta share how you setup the sequencing. I've been looking high and low for a way, but most of them are either expensive or are complicated diy setups with a dozen relays and diodes. I'm making homemade LED tail/brake/rev/turn signal lights for my GLW. So far, got one of my turn signals done. Used about 45 white bulbs in it, in rows of 4 in series with an 82 ohm resistor. Now I've gotta convert my turn signal flasher relay from the stupid comboswitch to a standard flasher that's electronic and not thermal, cause right now it flashes about 40 times a sec. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted August 10, 2011 Share Posted August 10, 2011 Are you guys that are custom fitting the LED blinkers are you doing the front too? Do the older stuff run 1157 bulbs in the front? Quote Link to comment Share on other sites More sharing options...
Cyfun Posted August 10, 2011 Share Posted August 10, 2011 I will probably be doing fronts eventually. Right now this is just an experiment. I think the stock fronts are those single filament bulbs. Quote Link to comment Share on other sites More sharing options...
