forresthicks4x4 Posted August 5, 2011 Share Posted August 5, 2011 I have an '84 GL with the EA81 and a 4-Speed D/R 4WD. My tranny is starting to go. Shifting into third gear is a problem. It doesn't like to go into gear, unless you get it just right; and good luck downshifting to third... If anyone has had this problem, feel free to comment, I want to know what's up. However, my real question is: Is it possible to swap a 5-Speed D/R from an EA82 motor into my Subaru? I know pretty much everything is possible, but just wondering. I need a new clutch, so when I replace that, I'd plan on doing the swap. Thanks a whole bunch Forrest Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 6, 2011 Share Posted August 6, 2011 This swap is very well documented - try a search and also check out the repair manual forum as there are several write-up's on it. GD Quote Link to comment Share on other sites More sharing options...
forresthicks4x4 Posted August 6, 2011 Author Share Posted August 6, 2011 Thanks GD! Quote Link to comment Share on other sites More sharing options...
