Dannoo93 Posted August 9, 2011 Share Posted August 9, 2011 so i was replacing my valve gaskets on my 92 loyale wagon and when i was almost done i was screwing the bolts in and it wasnt even getting tight and then poppppppppp...the lil thing the bold screws into broke that is inside the rocker arm area thing...and it looked like it was jbwelded in like it broke before...so now i cant get the gasket cover to tighten down all the way so it will still leak what do i do?Please any ideas will help Link to comment Share on other sites More sharing options...
Dannoo93 Posted August 10, 2011 Author Share Posted August 10, 2011 bummmpppp Link to comment Share on other sites More sharing options...
Quidam Posted August 10, 2011 Share Posted August 10, 2011 Dannoo93 said: bummmpppp You may need to replace the cam carrier. If you need one let me know, I can ship pronto. Doug Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 10, 2011 Share Posted August 10, 2011 Yep - TIG weld it and retap it or replace the cam carrier. GD Link to comment Share on other sites More sharing options...
idosubaru Posted August 10, 2011 Share Posted August 10, 2011 helicoil/timesert is the easy fix if there's enough material, which i would think there is, and you have or make room. the ghetto fix would be to tap it out to a larger thread size, use a larger bolt with flat head, and make your own crush washer/seal/oring for the bolt head. clearance may be tough, which one is it and do you have room? at which point cam carrier replacement may start looking mighty attractive. passengers side is the easier of the two if that's what you do. Link to comment Share on other sites More sharing options...
Dannoo93 Posted August 10, 2011 Author Share Posted August 10, 2011 no im just going to jbweld it for now im getting a 4runner in about 2 weeks Link to comment Share on other sites More sharing options...
Dannoo93 Posted August 11, 2011 Author Share Posted August 11, 2011 and there is not enough material to even tap or anything...the screw will only thread in maybe 2 screws Link to comment Share on other sites More sharing options...
