soobiefreak85 Posted August 12, 2011 Share Posted August 12, 2011 There are so many to choose from... which one works best and/or easiest? Thanks. Link to comment Share on other sites More sharing options...
Crazyeights Posted August 12, 2011 Share Posted August 12, 2011 (edited) With the heads off I use an OLD Snap-On one that looks like a giant C-Clamp - works great. With the heads installed it can be done too. I use an adapter for a compression tester with the schrader valve removed to pressurize the cylinder with shop air (holding the valves closed). I fabbed up something out of a scrap piece of steel I had laying around the shop to lever the springs down and remove the keepers (you do still have to remove the rocker arm shafts). Although this second method works it is sort of a PITA. Much easier with the heads off:) Be advised that there are at least 3 different styles of EA81 pushrods and at least 2 different height of valve springs that I know of. There are also at least 2 different versions of rocker shafts that I have found so far. Not all these parts will play well together in the wrong combinations. The smaller "overhead" spring compressors work really well too. I end up using those more for older V-8's though. Although this is made by Mac Tools, mine looks exactly like this one MAC-TOOLS-VALVE-SPRING-COMPRESSOR Edited August 12, 2011 by Crazyeights Link to comment Share on other sites More sharing options...
ShawnW Posted August 12, 2011 Share Posted August 12, 2011 I like how that one is assembled wrong but easily changed. Thats the kind I use on all Subaru heads and it works great. Link to comment Share on other sites More sharing options...
soobiefreak85 Posted August 13, 2011 Author Share Posted August 13, 2011 Great thanks guys! Link to comment Share on other sites More sharing options...
