86subaru Posted August 12, 2011 Share Posted August 12, 2011 will a 2.2 from a outback fit into and work in a 2002 forester, both automatic , any wiring problems plug and play ?? i have a chance to buy 2002 forester with a bad motor and i have a good 2.2 motor Quote Link to comment Share on other sites More sharing options...
Durania Posted August 12, 2011 Share Posted August 12, 2011 Fit yes. Think you just need to make sure that both engines are EGR or non-EGR. You will also need to swap intake manifolds. Quote Link to comment Share on other sites More sharing options...
86subaru Posted August 12, 2011 Author Share Posted August 12, 2011 ok, so the wiring is the same ecm ... etc. Quote Link to comment Share on other sites More sharing options...
987687 Posted August 13, 2011 Share Posted August 13, 2011 2.2 from an outback? So it must be from a 96 outback manual transmission? If it's from a 90's car and it's an outback. It will not work in a 2000 car. The manifold won't swap, the wiring won't match up. Quote Link to comment Share on other sites More sharing options...
86subaru Posted August 13, 2011 Author Share Posted August 13, 2011 (edited) the motor is from a 95 sedan put into a 97 outback, , the outback got wrecked,whats involed in replacing the rod bearing in a 2002 forester, Edited August 13, 2011 by 86subaru Quote Link to comment Share on other sites More sharing options...
987687 Posted August 13, 2011 Share Posted August 13, 2011 It would be much easier just to get a good 2.5 bottom end. It's kind of a pain to replace bearings in these motors. Quote Link to comment Share on other sites More sharing options...
86subaru Posted August 13, 2011 Author Share Posted August 13, 2011 ok, thanks Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 13, 2011 Share Posted August 13, 2011 Yeah - that engine will not easily work in the Forester. It uses a completely different intake manifold setup and will not plug-and-play with the EJ251's harness. GD Quote Link to comment Share on other sites More sharing options...
