Best way to remove wheel ring? ea81
I am prepping one of my '84s for sale and one of the rear wheels has some rocks stuck under the metal wheel skirt ring thing. The sound they make is a little "distracting". I would normally just rip them off, but there is probably some rust underneath, and I would rather let the next owner make that decision. So I am wondering about the best way to remove the skirts or just the rocks without mangling the metal.
If ya break one, Ive got 3 in pretty good condition you can take off my hands.
Thanks, I am going to try to get the pebbles out without removing the rings. I think the re-install would be the more likely step for damage. They flex a lot when I put leverage on them but don't unseat. High probability of tweakage if I go for it.
Mine come off every time I give the car a bath.
They come off with the pry end of a tire iron.
I smack them softly with a rubber mallet to reinstall.
If they havnt been off in a while smacking them with a rubber mallet might help. That should help break the bond they have with the wheel. Then pry them off.
Dont be surprised that the paint the wheels is horribly scraped up from the beauty rings once you have then off. Scrapes are inevitable. I usually scrub the wheels good, then hit them with spray wax to fend off as much corrosion as I can.
