dudesmccool Posted August 13, 2011 Share Posted August 13, 2011 I'm looking for a 170° thermostat for my 91 Loyale. Are ea81 thermostats the same? mods? help? Thanks guys! Link to comment Share on other sites More sharing options...
SoobDood05 Posted August 13, 2011 Share Posted August 13, 2011 I am not sure if ea81 or ea82 thermostats are the same, i just replaced mine today in my 90 loyale with one from Shucks, they usually have them in stock at your local parts store for around 8-10 dollars, and its an easy fix, hope this helps. Link to comment Share on other sites More sharing options...
dudesmccool Posted August 13, 2011 Author Share Posted August 13, 2011 Stock thermostat is 180°-190° ish. I perfer a 170°. Thanks though man. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 13, 2011 Share Posted August 13, 2011 The stock temp is what you should run - 192° is best for fuel economy and engine longevity. GD Link to comment Share on other sites More sharing options...
Crazyeights Posted August 13, 2011 Share Posted August 13, 2011 Not to mention the Subaru OEM thermostat is far superior to aftermarket ones. It is one part you really do want to spend the $20.00 for and get from the dealer. Link to comment Share on other sites More sharing options...
The FNG Posted August 13, 2011 Share Posted August 13, 2011 yup, what GD said. And learn from my mistake and buy OEM (that means from the dealersip --Fuji Heavy Industries) the first time. A thermostat from NAPA/schucks/car quest, etc may cost $10, but an OEM one is only $18. If you don't want to replace it twice, do this one right the first time. Link to comment Share on other sites More sharing options...
dudesmccool Posted August 13, 2011 Author Share Posted August 13, 2011 An oem thermostat is what I want. Having a the engine running cooler is better for longevity and performance. Link to comment Share on other sites More sharing options...
Crazyeights Posted August 13, 2011 Share Posted August 13, 2011 I would respectfully disagree. Being at the proper temperature is very important for both longevity and the ability to achieve the correct fuel mixture, especially on computer controlled systems. Of course there are exceptions to every rule (highly modified engines for example) or an engine that has a head gasket problem you are trying to limp along for a little while longer, ect. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 13, 2011 Share Posted August 13, 2011 The stock temp is what you should run - 192° is best for fuel economy and engine longevity. GD Hmmm... ...Having a the engine running cooler is better for longevity and performance. Well... I Agree with That! I Run my EA82 Without Thermostat since Many Years Ago and I've Noticed other Benefits... but here in the Caribbean tropics it's not Needed: Never Snows. Kind Regards. Link to comment Share on other sites More sharing options...
dudesmccool Posted August 13, 2011 Author Share Posted August 13, 2011 This is a mild decrese in temp, nothing major. Link to comment Share on other sites More sharing options...
Crazyeights Posted August 13, 2011 Share Posted August 13, 2011 I have never owned an EA82 - in the case of this engine you are probably correct. Especially if it's a turbo. Link to comment Share on other sites More sharing options...
eulogious Posted August 13, 2011 Share Posted August 13, 2011 (edited) The stock temp is what you should run - 192° is best for fuel economy and engine longevity. GD yup, what GD said. And learn from my mistake and buy OEM (that means from the dealersip --Fuji Heavy Industries) the first time. A thermostat from NAPA/schucks/car quest, etc may cost $10, but an OEM one is only $18. If you don't want to replace it twice, do this one right the first time. What these guys said. This has been talked about before, and the ea82 does not really benefit from lower temperature, especially in the "performance" category There is not to much more performance that you can get out of this engine, its already tapped out! In fact people have noticed downsides to doing this (except for in the caribean apparently). GD knows his stuff about this engine, and OEM is the only way to go with the ea82. You may think the ea82 is a "normal" engine to be treated like everything else, but it's not, and it's quirky. Do a search and you will find several threads that explain this. HTH! Edited August 13, 2011 by eulogious Link to comment Share on other sites More sharing options...
Uberoo Posted August 13, 2011 Share Posted August 13, 2011 subaru stuff is like 190* I run a 180* T stat from a chevy 350 with a bleed hole drilled in. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 13, 2011 Share Posted August 13, 2011 If you want to cool something - cool your oil. Lowerting the t-stat temp is not going to affect anything - coolant runs through the throttle body and the intake manifold - 20° cooler on the coolant temp will accomplish nothing and cause the SPFI computer to not run the correct mixtures. GD Link to comment Share on other sites More sharing options...
rpholz Posted August 13, 2011 Share Posted August 13, 2011 Oem subaru t stat is 190. I have a 185 oreillys in mine currently and it causes all sorts of problems. Not to mention the oem one actually looks to be of decent engineering and build. Not this flimsy pos that's in mine right now. Link to comment Share on other sites More sharing options...
The FNG Posted August 13, 2011 Share Posted August 13, 2011 Oem subaru t stat is 190. I have a 185 oreillys in mine currently and it causes all sorts of problems. Not to mention the oem one actually looks to be of decent engineering and build. Not this flimsy pos that's in mine right now. 100% correct. The OEM one weighs about twice as much too. Seriously, I think we buy these cars because we are cheap (at least I did). A $20 part is worth buying if it fixes the issue. Actually, if you want to be stubborn, go buy the cheap one because I love saying "I told you so!":lol: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 14, 2011 Share Posted August 14, 2011 (edited) ... - 20° cooler on the coolant temp will accomplish nothing and cause the SPFI computer to not run the correct mixtures... GD is absolutely Right. I Forgot to Explain that I Was Writing about the Carbureted Versions of the EA82, lowering the Operating temps won't help on the Fuel injected ones; instead, it will cause Malfunctions on those, as GD explained. ... In fact people have noticed downsides to doing this (except for in the caribean apparently)... Well... Yes! Somehow, Let me Explain: We have hot climates almost the 70% of the Year, when Temperature reaches nearby the 40º C (Around 104º F? I'm not Sure about the Temp Conversion 'cos we Use ºCelcious only) and just from November to January the Temperature Lowers nearby the 10º C (Around 50º F?) So Keeping an Old Carbureted EA82 Runnin' Cooler without Thermostat will Help it to prevent from Overheating (Those Trend to Overheat easily here, Specially if you Run the A/C on Traffic Jams for Long Periods of Time, and That's Usual on the Main Cities) so a cooler runnin' EA82 will end in Less Head Gaskets Changed; Also a Cooler Operating Carburetor is Better; even to prevent Fuel from Boiling. Also, here isn't needed the Catalitic Converter, so a Cooler exhaust isn't a Problem. Kind Regards. Edited August 14, 2011 by Loyale 2.7 Turbo Misspelled Word Link to comment Share on other sites More sharing options...
subynut Posted August 15, 2011 Share Posted August 15, 2011 I swapped to a 180 in my carbed EA82 in the summer thinking it would help it run cooler - nope, didn't help at all, still ran at 215 degrees in the mild desert heat on the interstate. What was worse, was the non existent heat and horrid mileage during the winter. Switched to an OEM 190 and my heat was back, mileage went up, and since the valve is larger on the OEM 'stat's, it ran cooler in the summer. OEM FTW! Link to comment Share on other sites More sharing options...
skishop69 Posted August 16, 2011 Share Posted August 16, 2011 As GD stated.... The engine will NOT go into closed loop mode if below 180 degrees. You be running enriched will will lower your mileage and show absolutely no power gains on the EA82. Where it is true a cooler engine runs better, longer and with more power, this does not apply to passenger cars in general. The engines are designed and programmed to run at a specific temp range. +1 for GD, put on an oil cooler. Link to comment Share on other sites More sharing options...
