EA81 into wild VW trike
Hi. My customised Vw trike made by Panther Australia is in the process of having an EA81 transplanted into it.
The VW 1916 engine is gone- sold.
The transmission is the old VW type 3 automatic.
Glad I can browse your pages for information like I do with the Aussie forums. cheers.
Thanks ShawnW. I love the uniqueness of this trike but in my view the 1916 VW engine wasnt the powerhouse I expected.
So a Subaru EA81 is now on the cards and is about week or two from installation. I chose it for its simplicity with a little more power and torque.
Engine as it was delivered
Engine as it is today cleaned up and waiting on some seals and heater tubes etc. after all 19 years of deteriation would make perishables likely to fail in our outback.
The adapter is on the engine now and will mate to the VW type 3 auto trans.
I've rotated the oil filler and dip stick to allow for ease of access from the rear of the trike and away from where I plan to place a Jeep cherokee radiator which is only 9" high.
The van weighs 380kgm dry. has all the necessities.
the trike even became a weddign cake item...
escorted by a 47 Plymouth
Hehehe... Tweety, you're move over here took a lot less time than mine did!
It's great to see some other pics of the trike and the camper too. The wedding cake figurines look awesome ;)
Can't wait to see how this thing shapes up with the EA81!
Cheers
Bennie
Here are a few more
needed a rear vision camera as mirrors would be too wide.
This is a shot of the demister!!!! two 12v hair driers inside two exhaust extensions
and the blonde?
Tony
Looks good.
Where did you get those mufflers?
I'm an old air cooled guy (still have a bunch) and have a similar header setup so that it's easy to get the valve covers off to adjust the valves on my street legal buggy.
How does it sound with only a small hole in the middle or each exhaust (seemingly about the same size as the stock "pea shooters") and why did you choose that exhaust?
Does look like a nice setup the trike and the camper.
Does the Blonde come with the camper?
Nah, the blonde is a model and they wanted pics of her on trikes at a show.
The exhaust is the standard fare you get with Panther Australia trikes. Absolutely hopeless system that severely restricts the performance. It was quiet though. the whole engine unit was sold couple of weeks ago.
I would suggest a simialr system for the Vw engine but bigger pipes and outlets.
The 1916cc engine didnt pull the camper all that well. Its HP was down although the engine was sound and had been rebuilt under warrantee. But I got the impression that to rebuild one of those engines you really need to do it fully and properly. Half measures like keeping the original cam and not installing a better exhaust really suffocates the performance.
So I cut my losses and went ea81 for that reason. Horses for courses though. I just wanted a bit more power/torque, bit more reliability etc. EG adjust tappets on the Subaru every 20-30,000kms on the VW every 3-4,000 kms, etc. What didnt turn me on was the thought of EMU's, clutter, etc. I like my engines simple and am not a rev head.
  tweety said:
And I'm not far from you as am in Strathbogie near Euroa. you must come for a brew....
Sounds too easy but time is against me :( I'll see what I can do, who knows, I might find a gap that lines up for both of us ;) Here's hoping!
Cheers
Bennie
Got the seal removal tool today
and the new seal just pushed in nicely
connector for breather installed
This pic shaws the breathing tubes from the valve covers around the rear of the engine out of sight from rear of trike
automatic kickdown switch
home made throttle cable mount
Engine on wheels ready for rear main seals before installation. Extendable air filter system to avoid radiator hot air
Pretty simple stuff but there might be other novices like me out there that will benefit...
I purchased the engine minus the Hitachi carbie and electronic dizzy from the owner.
Then I was lucky enough to want those two items and they were for sale on our Aussie Ausubaru forum that night.
With the carbie came the alloy top adapter and that air filter. I bought the blue extendable hose (76mm) from a speed shop.
Sorry cant be of much help sourcing out where you'd find them but all these items and the weber 32/36 carb were from the states.
Also one of our local assistants on forums looked at my valve cover hose pics and found a fault. One hose should go via the pcv valve and one hose sucks clean air in like a circuit. so more plubing to come there.
A top adviser for me is a fellow from Western Australia. "Toonga" told me today that the valve breather hoses hooked up that way wasnt right.
The hose on the dizzy side sucks clean air in at the original air filter housing. Then the air circulates and comes out the other valve cover hoses (alternator side) to go back into the engine through a PCV valve.
Prior to that PCV valve air also comes form the air cleaner housing to meet up with these fumes so the engine isnt saturated with gases, effectively making the mix less toxic.
The easiest way to rectify this with a weber conversion is to gwt two mini filters
http://www.ebay.com.au/itm/MINI-AIR-CRANKCASE-VENT-BREATHER-FILTER-15MM-CHROME-RED-/250814188569?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a65b0cc19
place one on the end of the breather hose of the dizzy side. I will then secure the filter to the top of the adapter plate.
The other filter I'll use a "T" peice prior to the PCV valve so air can be sucked in there. Essentially though they are treated as two seperate systems, one sucking the other blowing.
  • 2 weeks later...
Ready to strart up in the morning only for a few seconds as I havent got a radiator yet.
Electric fuel pump hooked up (safety cut off switch to come), all electrics at this point seem ok (labelled most things) Exhaust is to get me to the exhaust shop only. roo deterant
I had made a small pulley arrangement for the throttl BUT too much friction. ended up making this set up witha cable that doesnt snake and a lever that is simple.
I have swapped ideas on radiator location mant times. finally I am to order a custom one that will fit vertically over the transaxle. even though I reversed the oil filler it is still too far to the front so will get my engineer to alter it to angle rearward clear of that radiator. Radiator to be about 850mm wide, 260mm high and up to 40mm 3 core thick. plenty of wind from the sides available. two small thermo fans maybe 3 or 4.
Bit nervous starting it up. I'm no mechanic, in fact I'm a poor back yarder too. When younger I owned a Lotus powered car. It needed head work. I ended up pulling that head off 4 times before I got it to run. 1/ forgot to install a oil drain tube that sandwiches between head and block 2/ chain driven twin OH camshafts and chain had a split link...dropped it as I tried to connect it and down to the sump it went 3/ didnt syncronise the cams and bent all 4 inlet valves on the pistons 4 forgot to cut out the S/steel off the cheaper headgasket that would have coroded the alloy head. was an expensice excercise. hope I have success in the morning...
More progress. This is a $10 item at Bunnings. A steel shelf type rack.
Protects the engine side of the radiator. you can also see the expasion bottle mounted
Here is the expansion bottle access to the cap in an opening ormslly reserve for a glove compartment, an option I didnt take when trike was ordered.
air filter remounted.
The filter will poke out a bit less than this. Too far and it will impede on the roof retracting mechanism. This shot also shows the S/steel plates for the glove compartments. 5 louvre vents to cover these and add forced air to the radiator.
Edited by tweety
repositioned the expansion bottle so its above the radiator
So I found the highest point. And the bottom of the bottle is in line with the top horizontal core of the radiator.
You can see here the flexi radiator hoses are installed. one was 60cm the other 50cm.
One Hawsie pipe has been fixed. I am happy with this option.
You can see here the flow direction of air towards the radiator. Need some ducting. 12 inches circumference. so ducting about 4.5 inches diameter....have to start looking.
The temp gauge. I have a favourite spot beneath the instrument cluster.
gotta seek our some 50mm internal pipe...maybe pvc and paint it or chrome exhaust tip or similar to house it and protect it from the rain.
So what's left. Will get back my engine protection bar and modified oil filler Friday. Then start up and tune the best I can. Get it to the exhaust joint. Ride home!. engineer. camping...cocktails...
One of the things that annoys me with custom work is the negativity one gets from service staff at retail outlets. Some are good, others have no vision.
Today was no exception. Arrived at a large hardware store where there is prompt service. I didnt want to go through the ordeal of explaining such- VW chopper trike now with Subie engine and have ducts called Hawse pipes and need flexible pipe to direct air to the thermo fan etc etc. But I did say it all and got the common reply- "hope, you wont find that here". "Ill just have a browse then".....my common reply knowing full well I'll find something.
In the plumbing section I located a rubber sleeve and a flexible lower cistern pipe. And the rubber sleeve fitted onto the Hawse pipe perfectly.
This pic shows the advantage of that flexible section
The view from the side is more brighter with the flash. Can paint black
Add to that a straight 90mm section and it reaches the thermo fan
Not a cheap excercise. hawse pipes x2 $76, flexi pipes and rubber sleeves x2 $96, 90mm pipe $10. total $180 for this. but I think it adds tot eh overall appearance and hopefully a little more air into that area.
