retoque question.
  The FNG said:
Just saw another one of your posts. Are you using FelPro or B/A Head Gaskets? FelPro are not supposed to need a retorque and are the recommended gasket on the board here.
yea, i was replace new felpro but somehow have damage head gasket and milky coolant becuz of i was re-toque also over-tight after three steps..
so, B/A head-gasket should be re toque or not?
i'm ask how much ft lb for head cycle bolts?
i've been spend $ for three times, new head cycle also 8 times rebuilding on ea82. because of there was badly leaky (head cycle block, master cam-lobe leaky and oil pan leaky) :banghead: im totally Polish.
