Jub Nub Posted August 16, 2011 Share Posted August 16, 2011 so yeah, it runs like a cold carbed motor with no choke, i searched all over forum unsuccessfully, maybe i dont get how it works. dont think theres any vacuum leaks, any help is appreciated. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 16, 2011 Share Posted August 16, 2011 Any codes? GD Quote Link to comment Share on other sites More sharing options...
Subruise Posted August 18, 2011 Share Posted August 18, 2011 fuel filter. happened to my 91. good luck RV Quote Link to comment Share on other sites More sharing options...
Jub Nub Posted September 7, 2011 Author Share Posted September 7, 2011 thanks for replies, sorry for my sporadic posts, i have limited access to the car as it belongs to my brother. @GD, im getting 34, 35, and 51 = purge solenoid, egr solenoid and neutral switch always in on position, according to code list i found on here. I seem to have read that neither 34 or 35 matter as far as the engine is concerned, but for the neutral switch, my brother and i just put in a DR 5sp in place of his SR 5sp, not sure bout the switch placement. @RV ill try the fuel filter as soon as im done posting, since i have one and just havent put it in yet = / thanks again Quote Link to comment Share on other sites More sharing options...
Jub Nub Posted September 7, 2011 Author Share Posted September 7, 2011 fuel filter didnt help, still acting the same way.. runs fine at idle and just off idle, try to throttle it more than that almost kills it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 7, 2011 Share Posted September 7, 2011 Check your fuel pressure. GD Quote Link to comment Share on other sites More sharing options...
dennyt Posted September 7, 2011 Share Posted September 7, 2011 Is the air flow sensor plugged in? Quote Link to comment Share on other sites More sharing options...
