mattocs Posted March 11, 2004 Share Posted March 11, 2004 I have a noise coming from the drivers side front tire when I apply the brakes. My only guess is that the brake pad is so far worn down that its just pressing metal against the roter or whatever it does...heh. My question is...are there any other things that would make this sound when you press on the brakes? Or is my guess most likly correct? Link to comment Share on other sites More sharing options...
theotherskip Posted March 11, 2004 Share Posted March 11, 2004 depends on the noise, but it is worth getting checked out immediately. not too wise to ignore noises coming from the front end... Link to comment Share on other sites More sharing options...
jimpomm Posted March 12, 2004 Share Posted March 12, 2004 Dont some of the newer cars have wear sensorsthat make noise?Describe the noise to us that helps. Link to comment Share on other sites More sharing options...
cookie Posted March 12, 2004 Share Posted March 12, 2004 But it could be a wheel bearing too. Jack it up and spin it and rock it for play. Then pull the wheel and inspect the brake pads. Should tell you right there. Link to comment Share on other sites More sharing options...
EOppegaard Posted March 12, 2004 Share Posted March 12, 2004 What about turning? That could be a loose gasket on the axel...forget the exact name of it. However I agree that it is probably a brake pad. If you end up changing it yourself, let me know, I am interested in attempting a brake job on my 1993 legacy just to replace the pads. Link to comment Share on other sites More sharing options...
Setright Posted March 12, 2004 Share Posted March 12, 2004 Eop, you really ought to replace the rotors at the same time - o rat least have them resurfaced. You will run into premature problems if you replace only the pads. Btw, brake job is quite easy, and there will be plenty of support from this site Link to comment Share on other sites More sharing options...
