superbrat84 Posted August 19, 2011 Share Posted August 19, 2011 the connector on the cooling fan looked corroded so i got some flat connectors at autozone and fixed the connection that way. i have replaced the radiator cap. temp looks normal (i also run the A/C) and yet it keeps running itself out of coolant? and i haven't overheated it yet but it starts climbing and i shut the car off imediatly. any ideas is there supposed to be a coolant resivior that coolant goes to? oh another thing when i bought the cap i had to buy one for a 1980 subaru brat. so any help is appreciated. Link to comment Share on other sites More sharing options...
bheinen74 Posted August 19, 2011 Share Posted August 19, 2011 water pump is seeping out the bottom. Link to comment Share on other sites More sharing options...
Txakura Posted August 19, 2011 Share Posted August 19, 2011 I just had a 90 Legacy barf it's guts out due to a stuck thermostat. It got pretty hot and came back up the overflow reservoir. You said the temp seemed normal but that it was getting hot and you were shutting it off? +1 on the weep hole in the water pump (btw) Link to comment Share on other sites More sharing options...
mcbrat Posted August 19, 2011 Share Posted August 19, 2011 if it is all coming out the overflow, then you most likely have a bad headgasket that is allowing the exhaust gas into the coolant passage... I had that happen on Mtn Grizzly once... Link to comment Share on other sites More sharing options...
