cohophysh Posted August 21, 2011 Share Posted August 21, 2011 (edited) 90 leg. 2.2 Are the cooling fan relays the two relays closest to the firewall in the relay box? The owners manual shows the fuses but not the relays. If they are the fan relays, which is which? Edited August 21, 2011 by cohophysh Link to comment Share on other sites More sharing options...
cohophysh Posted September 13, 2011 Author Share Posted September 13, 2011 bump Link to comment Share on other sites More sharing options...
cohophysh Posted September 13, 2011 Author Share Posted September 13, 2011 So if I swap the relays and the main fan still doesn't come on, is there a temp switch I should check or should I just replace the fan at this point? Link to comment Share on other sites More sharing options...
ShawnW Posted September 14, 2011 Share Posted September 14, 2011 I would be checking the fan manually first and make sure there is no corrosion in the plug to the fan itself. Much more often this is the case than the relay. Then the wires going into the bottom of the main relay/fusebox under the hood are also commonly pulled out for some reason. Link to comment Share on other sites More sharing options...
