ea82 swap
dtek
well i have a 86 xt with the ea82 N/A that is gettin tired i have another ea82t lined up. but i heard you could swap it with a ej22, what all would i need to do this swap. or should i just stay with the ea82 set up, any ideas thanks
Don't bother with the EA82T, if you do a search here you'll find hundreds of threads about its problems. The EJ22 swap is much better and produces more power. Do a search for this too, theres several people here running ej22's in there EA82 bodys using both the stock EJ22 EFI system and also some with weber carbs. SJR makes adapter plates to bolt an EJ right onto an EA82 tranny along with modified flywheels.
Always search first:grin:
Welcome to the USMB!
