exactly... i've been trying driving for short but RPM was high became lower to shut down... ive been turn over again but shut down...
whats its?
  lmdew said:
Sure it's the Oil Temp and and not the AT Temp?
AT Temp flashes 16 times after you start the car when there's a transmission fault.
  Suba_GL_87 said:
my girlfriends car is Subaru Outback 96' EJ25
ive been try starting became fire up but somehow shut down with during (temp oil light flashing)?
thats mean need repair new oil or what?
whats its?
Umm, what? Can you clarify what you are asking here? Your questions and responses are really confusing :confused:
Is your AT Temp light flashing 16 times at startup? What are the car's symptoms?
actually.. i was replace new fuel filter and somehow my wagon wont running as last.. i did waiting for 5 min running but still no good.
when i was start it like a 10 sec later shut down...with oil temp flash.
i did put the right of the fuel filters hose (in & out)
i try running but it just shut down...with during "oil temp" flash.
what u mean cross the fuel lines??
  lmdew said:
These are two seperate problems. The Flashing AT Temp light has nothing to do with it not starting!
Did you cross the fuel lines?
