High altitude Weber jetting
spazomatic
Howdy readers!
just got a used weber, and I'm curious what size jets you're running in yours at high altitudes. my place is at 8000ft, but I typically run around as low as 5000 ft, up to 10000 ft or so.
the carb came from just above sea level, and has *40 jets in it.
thanks for your input!
Dan
but on the other hand...it was no help at all. seein's how it says a lot of "if you do not know the original blah blah, buy a selection of jets"....
which is what I'm trying to avoid. a lot of spare parts I won't use, and time spent on needless teardowns and rebuilds. :slobber:
so um...you guys with webers at high altitudes...what size jets are you using?:banana:
