Lachlan Posted August 26, 2011 Share Posted August 26, 2011 I have an 81 Cali Brat, but have replaced the cali hitachi carb with a weber. Is there anything else the ECU really controls? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted August 26, 2011 Share Posted August 26, 2011 i pulled mine out once upon a time and found out that it controls the electric choke as well (DOH!) So...i put it back in and just live with the stupid check engine light to let me know that there is zero emissions stuff under the hood and the computer is freaking out. If you want to wire up the electric choke yourself then by all means yank it. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 26, 2011 Share Posted August 26, 2011 You can swap over to the black FPCU and run the wire for the choke control to the carb - then you can eliminate the ECU. GD Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted August 26, 2011 Share Posted August 26, 2011 I have a CA 85 Brat with weber and computer is unhooked. I used a different hot when on wire for choke wire. -Now i know why the original choke wire wouldnt work on weber. Quote Link to comment Share on other sites More sharing options...
Lachlan Posted August 26, 2011 Author Share Posted August 26, 2011 Cool. I use a manual choke, so I guess my brain completely replaces the ECU! Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 26, 2011 Share Posted August 26, 2011 Could I Ask What is... ...the black FPCU ... ...? Kind Regards. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 26, 2011 Share Posted August 26, 2011 The Fuel Pump Control Unit - they made them in variety's that control the fuel pump only (blue box), and one's that controlled the fuel pump AND the electric choke (black box). GD Quote Link to comment Share on other sites More sharing options...
81EA81 Posted August 26, 2011 Share Posted August 26, 2011 Is that the little box that has a mitsubishi logo on it? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 26, 2011 Share Posted August 26, 2011 The Fuel Pump Control Unit - they made them in variety's that control the fuel pump only (blue box), and one's that controlled the fuel pump AND the electric choke (black box). GD Thank you for your Kind Answer... Best Regards. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 26, 2011 Share Posted August 26, 2011 Yeah - it has a mitsi logo on it. Generally located right above the hood release cable bracket above the driver's left knee. GD Quote Link to comment Share on other sites More sharing options...
