danzick Posted August 26, 2011 Share Posted August 26, 2011 so i dont know if this is just how the cars are, but i have an 88 gl 10 wagon. it has a 3 speed automatic in it :-\ which probably doesnt help the power out. its got some mid range issues where it seems to loose a little power at mid range. i cleaned the MAF sensor, brand new CTS, fuel filter is good, and so is air filter. re built motor like 10 thousand miels ago, doesnt burn a drop of oil and the oil is very clean at 300 miles now, i took the EGR out, and i took both of the cats out. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 26, 2011 Share Posted August 26, 2011 It's got 90 HP..... it's not going to be fast unless you put in a larger engine. GD Link to comment Share on other sites More sharing options...
danzick Posted August 26, 2011 Author Share Posted August 26, 2011 i guess im just surprised they would make a car that takes like 5 miles to get to 70 mph? and i have a Crank angle sensor that keeps pooping a code. does that affect how my engine runs? Link to comment Share on other sites More sharing options...
92_rugby_subie Posted August 26, 2011 Share Posted August 26, 2011 its probably because its an auto... or youre not punching it hard enough. I can get my carbed 86 GL to 70 before 5 miles is up... Hell before a mile is up... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 26, 2011 Share Posted August 26, 2011 ...well, Mine too; Specially since the Weber Swap; So there's Something Wrong with that Subie. Maybe a Tune-Up can help... I Mean New Spark Plugs, set the Timing Right, Check for Worn Vacuum Hoses, etc... Kind Regards. Link to comment Share on other sites More sharing options...
SoobDood05 Posted August 27, 2011 Share Posted August 27, 2011 it is an AT 3spd right? but it should atleast have some power, my 90 loyale will make it to 70 in under a mile, happened to have 1980 thru 94 manual handy so heres the trouble shooting for engine lacking power. . 1.Incorrect ignition timing. 2.Exesive play in distributor shaft 3.worn rotor igniton coil or plugs plug wires 4.faulty or incorrectly gapped plugs 5.problem with carburator/fuel injection system. 6.plugged air filter 7.brakes binding 8.Automatic transaxle fluid level incorrect 9.fuel filter clogged/ impurities in fuel system 10.emission control system not working properly 11.low or uneven cylinder compression 12.obstructed exaust system. Kudo's SDO5 Link to comment Share on other sites More sharing options...
danzick Posted August 27, 2011 Author Share Posted August 27, 2011 ok, i may have exaggerated. but like when i get on the interstate around here, its at a slight uphill, and it takes about 2 miles realistically to get up to 70. and no its not real steep. its just up hill very slightly. and i got new plugs in it also, its the mid to low rpm sorta hesitation thats bothering me. still wonderin if the crank angle sensor could have something to do with that? Link to comment Share on other sites More sharing options...
