Bajamansam Posted August 27, 2011 Share Posted August 27, 2011 Car: 2003 Baja 2.5 liter auto tranny Job: Timing belt replacement Question: Where exactly is the fly wheel access hole? I want to use the "jam the flywheel method" to get the crank pulley off. I have read in other threads that there is an access hole below the breather box, but I cant find it on this car. I removed the breather box and can see the area where the engine and tranny join very well, but don't see or recognize the access point Please help! Thanks Brothers Link to comment Share on other sites More sharing options...
Bajamansam Posted August 27, 2011 Author Share Posted August 27, 2011 I found it on a YouTube video. Ain't the internet great! Link to comment Share on other sites More sharing options...
johnceggleston Posted August 27, 2011 Share Posted August 27, 2011 is this what you want? post #46 http://www.ultimatesubaru.org/forum/showthread.php?t=119808&highlight=screwdriver+google&page=5 tagline: flexplate screwdriver Link to comment Share on other sites More sharing options...
Bajamansam Posted August 29, 2011 Author Share Posted August 29, 2011 That's a good view of what your shooting at, but the access plug I found and used is located under the aluminum air intake neck. You can see it after taking the air filter box off the car. The hole opening is covered by a hard rubber plug. When the plug is removed, you can see hole in the plate. Turn the crank bolt while looking in the hole and you will see an opening in the plate that you can slip the scew driver in to bind the rotation, and holding the crank so you can either remove or install the crank bolt. I finished the job today, and I swear the car runs smoother now. I guess the old belt was stretching (is this possible?) or could it just be my superior mechanic skills? Link to comment Share on other sites More sharing options...
Olnick Posted August 29, 2011 Share Posted August 29, 2011 I finished the job today, and I swear the car runs smoother now. Well of course. They always do. And yes, I too rack it up to my superior mechanical skills. Good job. Enjoy! Link to comment Share on other sites More sharing options...
