pull it and clean the mating surface of the engine and knock sensor - maybe a piece of debris is between the two.
make sure the knock sensor connector didn't get pulled apart on the vehicle/body side harness. sometimes they are about 10x harder to separate than they seem like they should be. :rolleyes: if you had to tug on it when removing then you could have pulled the pin out of the harness connector (i've seen it happen before). seems unlikely, but so does your current situation - but maybe it's loose, partially pulled out?
