bonvos winter warrior
so i think i have a plan of attack
stock
the plan
a slight lift of about 2 inches bigger more agressive tires but not so big that i have to cut the body some extra lighting on the front and rear
im going for a rally kind of look something that looks like it can go anywhere but not look like a rock crawler
alright i got it home!!!!!!!
loading it
trying to get out
gave up and crawled out the passenger side which was no small task
whos tailgateing me... casper
destination reached
i have got to do something about the seats they sit to high and the steering wheel is in my crotch
unloaded the goodies
these may be all aluminum but damn there still heavy
next to michelle i looked at them side by side there is somthing wrong when my station wagon is 3 inches shorter then my 2 door coupe
so today we filled the radiator adjusted the carb and wired the fan to a toggle switch since the stock thermo switch is dead also fixed the temp gauge
all in all a good day
today was cleaning day i washed it cleaned out the interior scrubbed the engine bay cleaned up and painted the push bar the rims with the best tires on them started bleeding the brakes but when my sister prooved to be less then helpful at working the brake pedal i gave up ill try again later i also replaced all the vacuum lines going to the carb and put a new radiator cap on it so the cooling system will hold pressure
ignore the chunk of vacuum line on the seat
then i remembered i had the stock hubcaps from shelly and that they were 13's im glad i hung on to them
cleaner engine bay
thats just normally how loud they are? if so damn there loud bastards lol
one thing ive noticed and im starting to like alot about this car is that its spunky and it sounds pissed off
Edited by bonvo
i think i scored with a price of 200 bucks even if i have to put another 200 or so into it ill have a running driveing 4x4 for the winter and a cool little rallyer in the summer all for about 400 just a win win situation
as tempting as that is i want whatever wheel i put under it to fit in the wheel wells this wagon is to clean to cut it up a mild lift and some 14 inch datsun wheels will probibly do the trick with some meaty snow tires give it the rally going look i want
well today after work my dad and i bled the brakes and i installed a tach now that i got to drive the car faster then 5 mph the speedo doesnt read past 20 and the clutch slips baaaaad but other then that its a solid car
a few questions one why would the speedo only read up to a certan point? number 2 the gas gauge doesnt work i put 1 and a half gallons in it todat and it didnt even budge on a tank that is only 11 gallons it should register something right? my temp gauge kinda works i know there is some corrosion in the connecter to the sensor but are they any other causes that could be causing me to have these instrumentation issues?
Edited by bonvo
well i got a clutch for it and for free non the less! local subaru guy had it laying around i asked how much he wanted for it and he said free get it out of my life so for 200 bucks plus the cost of registration i have a 4x4 for the winter can we say winning? cause i can
