bonvos winter warrior
well since the engine thats in the car is low on compression i pulled the complete engine that i got with the car out of the shed and took a look at it to see if its worth re ringing it so i can just swap motors instead of having the car down for a week
parts
2 of the bores had some rust in them after cleaning this one turned out nice
this one not so much
and with the oil pan off
so were gonna try honing it and if that bore doesnt clean up then ill pull and re ring the engine in the car
well spent a half hour lazily pulling things apart im waiting for my dad to get home so i can borrow his picker and yank it so i figured i would pull some spoob off that im gonna have to pull off anyway
tomorrow im gonna drain the oil out of it and unbolt the rest so that its ready to pull when he gets home friday
well i leaned something new about my engine the water pump is completly contained the cast pipe up top is what connects it to the cooling passages instead of having everything inside the block half casting
found my exhaust leak
all thats left now is oil pump exhaust bell housing and motor mounts
some may say that im going slow with this but i cant do anything else till friday when i can get the cherry picker so im taking my sweet rump roast time to kill bordum
  • Like 1
  On 3/27/2013 at 2:22 AM, sikend667 said:
theres only one thing i enjoy more than a garage motor build...... thats one i get to watch not have to do lol
I agree but I need to do this as well.  So maybe this will give me some inspiration?
Mucho pics por favor.
this is how we started today
head off first peak in the bores
bell housing/ timing cover off
oil pan off
wrist pins were giving us trouble tools for extraction
video of the halves coming apart
everything laid out on the bench
this is what the bores looked like
got the hone out
bores afterwards
painted some parts
bores after a hone
now question for you guys is this a ghetto white trash or other hot tank
Edited by bonvo
hit a snag today here are the old bearings
these are the new
see whats wrong? one lock tab is in the wrong place the 5 other main bearings are perfect but 1 of the trust bearings has the lock tab in the wrong spot calling my parts supplier tomorrow about it
cleaned up and painted the radiator and fan set up while this pistons soak in the dip
Edited by bonvo
