ignition condenser
Pretty sure a 78 dl would have had breaker points as standard. Maybe someone has upgraded to breakerless since then and not bothered to ditch the condenser.
Have a look under the dizzy cap and see.
That said if it is still breaker points then the engine would not run without the condenser connected.
Checked under the cap and it has points. The Haynes manual gave the impression that it would be breakerless, maybe some other model from that year.
I did a little research on condensers and found that they basically keep the points from burning up from too high a current. Guess I should put a new one in before the points burn out.
