Ioku Posted August 31, 2011 Share Posted August 31, 2011 So I was doing some reading on transmissions and noticed that the RX low gear is 1.19 to 1 basically 1.2 to 1 so would it be possible to put those gears in place of the 1 to 1 high gears in the 4wd trans out of a GL and then have the 1.6 to 1 low gears. With the GL's 3.9 diffs and the 1.2 to 1 it would be like having 4.68 gears in high range this would make turning a big tire like a 31 feel like stock or even a bit lower. Not sure if this would be possible can those high and low gears be pressed off a shaft or is it just one machined piece? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 31, 2011 Share Posted August 31, 2011 No it is not possible. GD Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 31, 2011 Share Posted August 31, 2011 There isn't 1:1 high gears. The shift collar just locks the two halfs of the input shaft together, rather than re-routing the power through the reduction gears. Quote Link to comment Share on other sites More sharing options...
Ioku Posted August 31, 2011 Author Share Posted August 31, 2011 Ok, that would make more sense then having extra gears in there just to be 1 to 1 I guess I'll have to go to the other end of the gears and try that 4.11 or 4.44 diff conversion. Quote Link to comment Share on other sites More sharing options...
roostema4328 Posted August 31, 2011 Share Posted August 31, 2011 cant do that either unless you swap in an EJ transmission. then you would not have 4x4 anymore. you would only have AWD. you could put in a spool then have true 4x4 but than the driveability on the road would suck on corners it would hop. the only real option that would work is an EJ dual range. you can swap the 4.4 gears and the GL low range into that. But they are only in Aus. Good luck getting your hands on one of them lol. Quote Link to comment Share on other sites More sharing options...
