'97 Impreza OBS - Gas tank interchange
Just out of curiosity: how much fuel was really spilled, according to the gas gauge (i.e. the gauge went all the way up and after a few miles indicated just half a tank)? Are you sure the fuel made it to the tank in the first place :) ?
If the leak is somewhere low in the tank you can probably patch it, but to know which other cars have a similar tank you can look for the part number currently in your car (subarupartsforyou will help). They say there was a change in '97, so you may want to call them with your VIN to see which one is the right for your car.
Probably rotted around the nipple for the filler neck hose hooks onto the tank.
You have to drop the exhaust, driveshaft, diff, and rear crossmember to get the tank out. Maybe just fill it to a half tank?
You can take a look at it through the access covers under the rear floor. If the sender is leaking, you can replace that without dropping the tank. If the tank is leaking, there's a permatex tank patch kit that has fiberglass and epoxy resin it it that you can coat the area with. It's a pain to get in there though.
If you drop the tank, you will need to replace every pipe, hose, and clamp under there, and there's a bunch of them. If the rest of the car is in good shape, it's worth it. But if the quarters and rockers are rusted through, it might be time to take it off the road.
