87 GL dash lights
Hi all,:) the dash lights wont work on my buddys 87 GL is there a fuse for the dash lights? if so what is the fuse called, i cant seem to find it, if no fuse is there a plug that somehow came loose? dash has recently been taken apart so something could have came undone possibly. any input would be appreciated:grin:
  • 4 weeks later...
I had a similar problem with my 91 Loyale. I had no dash lights and my marker lights/tail lights would not come on unless I flipped the parking switch on top of the steering column. This was caused by a bad relay under the dash above the fuse box. There are 3 or 4 relays under there. one for each headlight, one for the 4wd. one of the headlight relays include the dashlights. do a search on USMB for headlight relays.
