SoobDood05 Posted September 1, 2011 Share Posted September 1, 2011 Hi all, the dash lights wont work on my buddys 87 GL is there a fuse for the dash lights? if so what is the fuse called, i cant seem to find it, if no fuse is there a plug that somehow came loose? dash has recently been taken apart so something could have came undone possibly. any input would be appreciated:grin: Link to comment Share on other sites More sharing options...
Dj7291993 Posted September 1, 2011 Share Posted September 1, 2011 Sorry I don't have time to look for you, but here is a wiring diagram for '87. Link to comment Share on other sites More sharing options...
Cougar Posted September 1, 2011 Share Posted September 1, 2011 Check the dimmer control circuit. I assume you have already made sure the control is set to the max position. Link to comment Share on other sites More sharing options...
SoobDood05 Posted September 2, 2011 Author Share Posted September 2, 2011 Thanks for the diagram, will check it out here soon!, and yes the dimmer was the first thing i checked:lol: Link to comment Share on other sites More sharing options...
NICALM Posted October 1, 2011 Share Posted October 1, 2011 I had a similar problem with my 91 Loyale. I had no dash lights and my marker lights/tail lights would not come on unless I flipped the parking switch on top of the steering column. This was caused by a bad relay under the dash above the fuse box. There are 3 or 4 relays under there. one for each headlight, one for the 4wd. one of the headlight relays include the dashlights. do a search on USMB for headlight relays. Link to comment Share on other sites More sharing options...
