86subaru Posted September 5, 2011 Share Posted September 5, 2011 been sitting 1.5 yrs , no start, timing belt good [ new] battery new, alt, all it does is crank , going to try again and get it running , just one day would not start Link to comment Share on other sites More sharing options...
johnceggleston Posted September 5, 2011 Share Posted September 5, 2011 has it ever run on the new timing belt? did you replace the timing belt? when it quit running, was it on the old belt? spark, fuel, and compression, which ones do you have? Link to comment Share on other sites More sharing options...
86subaru Posted September 5, 2011 Author Share Posted September 5, 2011 yes it ran on new timing belt, aleast 6,000 mi , everything ran great , no start, replaced crank sensor, plugs, wires, maf , Link to comment Share on other sites More sharing options...
86subaru Posted September 5, 2011 Author Share Posted September 5, 2011 got to get it running or junk it, township sent letter about the car sitting Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 5, 2011 Share Posted September 5, 2011 Pull one of the fuel lines off the fuel filter and make sure it's getting fuel. Just stick the end into a bottle then turn the key on. Check fuses? Link to comment Share on other sites More sharing options...
86subaru Posted September 5, 2011 Author Share Posted September 5, 2011 ok, will try it ,checking crank sensor i broke off the end part on motor , whats the best way to fix it, Link to comment Share on other sites More sharing options...
Prwa101 Posted September 5, 2011 Share Posted September 5, 2011 id check the psi in each cyl, in my 90 loyale that i have it sat for a while and when i went to start it did the same thing. turns out had 0psi and the rocker arms some how fell off when the valves stuck, with a little WD40 and some time fired right up! Link to comment Share on other sites More sharing options...
86subaru Posted September 5, 2011 Author Share Posted September 5, 2011 ok, been workin on it for 2 hrs no luck, just crank crank, so may call junk yard tomorrow, + other wagon sitting there with bent control arm, no help with replacing it , steel is up , thanks for all help, Link to comment Share on other sites More sharing options...
