This seems to tight... EJ shift linkage q's
biggreen96
That is the little rubber block the EJ shift linkage rides on, but the drive shaft is so close to the body that there wont be room. I had planned to bolt it on or weld it on but that idea is nixed now.
I take it most swappers are using the EA linkage, will there be enough room for that even? Does my driveshaft look like it's in the right place?
