illanrob Posted September 10, 2011 Share Posted September 10, 2011 (edited) 1993 Legacy 2.2L 5spd has a coolant leak at the bottom part of water pump gastek after replacing the radiator cap, the old had 0lbs the new has 9lbs. The pump bolts were loose and the gasket replaced 60Kmi ago turned to mush. Just a steady and fast coolant leak until radiator runs dry. The new gasket with carefully torqued bolts 7ft-lbs did better but still has a leak a drop a second from the same spot. Could the water pump be warped? Will try to check with a straight edge for flatness. Edited September 18, 2011 by illanrob Leak persists with new gasket Link to comment Share on other sites More sharing options...
johnceggleston Posted September 10, 2011 Share Posted September 10, 2011 no that does not make sense. the water pump leaking or the t-stat housing / gasket leaking makes sense. when was the last time you change the water pump? timing belt? Link to comment Share on other sites More sharing options...
illanrob Posted September 10, 2011 Author Share Posted September 10, 2011 (edited) The timing belt change is due at 210K 3rd belt, the car has almost 200K, the water pump replaced at 160K 4 years ago. The old water pump was very noisy as it approached total failure and is located on the driver side head. This leak is from the bottom of the block just in front of the oil pan, an is at the water pump. All 6 bolts were loose, my doing althouth it lasted several years. I got disoriented looking up and confused the two pumps thus posted on this forum for a sanity check. Thanks for the reply. Note that the manual does have a water pump tightening sequence 1 (upper driverside) clockwise to 6 (upper passenger side) bolt order. A 22MM socket takes the crank pulley off. Edited September 11, 2011 by illanrob Dissorinted on location of leak Link to comment Share on other sites More sharing options...
Fairtax4me Posted September 10, 2011 Share Posted September 10, 2011 There are NO coolant passages in the oil pump. The water pump is NOT attached to the head. It is attached to the block and is less than 1/4" away from the side of the oil pump. http://i6.photobucket.com/albums/y231/Freakness/Update%2021/Motorviewshowingwaterpumpinstalled.jpg You probably have a failed water pump gasket or block plug seal. Crank pulley bolt is 22mm. Link to comment Share on other sites More sharing options...
Pierobon Posted December 22, 2013 Share Posted December 22, 2013 I have this precise problem too, 1996 Legacy, H4 2.0L engine. I took the entire engine apart to clean and assembled it with 100% new gaskets. Subaru service manual says I need to tight the screws to 10Nm+4-0, first attempt I went to 12Nm, second attempt I tried 14Nm, third attempt I was pissed off and tried to glue both sides of the gasket with Loctite 5699 Gasket sealant, In the 4th attempt I tried using a sandpaper in the flanges and gasket to improve gluing, used the same glue and original gasket, tightened to 16Nm (that's 20% more torque than the limit on the service manual, 60% more than the recommended value). I don't know what else to try, the water pump and the engine block were both measured and there are no bends at all in either flange. Please someone help, If nobody has an answer to me I will try to glue the pump to the engine block without the gasket (like the engine block and oil pan and oil pump), but I really didn't want to decrease the gap - please help! Thanks! Link to comment Share on other sites More sharing options...
upnorthguy Posted December 22, 2013 Share Posted December 22, 2013 Are you using a new Subaru OEM water pump gasket (metal)? If not, the third-party gaskets sold at auto parts stores really suck. I tried one of those papery monsters on a whim while waiting for other parts and it absolutely did not work. Once I got my OEM gasket from a dealer, I used some very fine sandpaper and sanded the water pump and the block where the pump sits. This solved my leak. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 22, 2013 Share Posted December 22, 2013 Paper gaskets are junk! Like Upnorthguy said, get a dealer gasket. It's rubber coated steel, and will have no problems sealing. Get a thermostat housing gasket from the dealer as well. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 22, 2013 Share Posted December 22, 2013 a very talented and knowledgeable subaru mechanic who posts here every day claims to use no gasket. he just uses RTV, like the oil pump. i did a timing belt / water pump change once, and i failed to tighten one of the bolts. i just missed it. it leaked like a sieve. that is when i learned to refill with water until you are sure there are no leaks. and to test run the engine with the t-belt on, but the covers off, to see if it is right. way easier to go back if the covers are not yet on. 1 Link to comment Share on other sites More sharing options...
Pierobon Posted December 23, 2013 Share Posted December 23, 2013 Yes everybody, I only use original subaru stuff from subaru dealer. Steel painted black in this particular case. I guess tomorrow morning I'll try trashing the OEM gasket and going for the glue... thanks for the tip john I'll post my results when I'm done. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 23, 2013 Share Posted December 23, 2013 There must be some serious wear on that mating surface if a dealer gasket won't seal. Are you sure all of the old gasket material is removed from the pump and block? Should see nothing but shiny clean aluminum. Is the pump new? It's possible the bolts were over tightened originally and warped the pump housing. You could try RTV or paint the gasket with Indian Head gasket shellac. Indian head takes a while to dry but makes a very good seal. Link to comment Share on other sites More sharing options...
idosubaru Posted December 23, 2013 Share Posted December 23, 2013 On 12/22/2013 at 1:53 PM, Pierobon said: ISubaru service manual says I need to tight the screws to 10Nm+4-0, first attempt I went to 12Nm, second attempt I tried 14Nm, third attempt I was pissed off and tried to glue both sides of the gasket with Loctite 5699 Gasket sealant, In the 4th attempt I tried using a sandpaper in the flanges and gasket to improve gluing, used the same glue and original gasket, tightened to 16Nm (that's 20% more torque than the limit on the service manual, 60% more than the recommended value). something else is wrong - these things are cake and always easily seal when installed properly 100% of the time. i almost can't believe that sealant was used and it leaked, that doesn't make any sense at all. that's a lot of work already - i'd check threads of every bolt hole and make sure they're clean and not stripped. maybe use longer bolts to catch more/deeper/unused threads. get a new water pump Link to comment Share on other sites More sharing options...
Pierobon Posted December 23, 2013 Share Posted December 23, 2013 I am sure there is no wear, no bending and no materials from the old gasket. Clean, shiny and tidy. Just very little scratched cause I used sandpaper to glue the RTV thingy twice. I just didn't try to RTV without the OEM gasket, cause I didn't want to change the gap distance, but since someone here already does that I guess there won't be any problem. Just a strange observation I have to add, looks like RTV has poor adhesion to the gasket itself, it's probably made to adhere to aluminium or steel directly and the gasket is painted (rubber-coated someone said here). I will just be obsessively extra sure that I won't overglue the flange, cause the hole where the coolant goes into the engine block is so tiny, omg! I would risk a guess: Subaru designed all the flanges but the engine head to use RTV, but here manual tells people to use the gasket, so there's no risk of gluing the hole itself LoL Link to comment Share on other sites More sharing options...
Pierobon Posted December 23, 2013 Share Posted December 23, 2013 Applying the RTV sealant and screwing the pump on the block took me 9 minutes, way below the 20 minutes limit of "dry to the touch" time that says on the packing. Mission Completed. Used no gasket this time, hope there is really no problem at all. Still concerned about this: http://www.mototuneusa.com/power_news_--_how_to_blow_up_an_engine.htm Let's see what happens! Will wait 24h to dry, only then I'll put the glycol back on the engine to test. Time for a pint! Link to comment Share on other sites More sharing options...
idosubaru Posted December 23, 2013 Share Posted December 23, 2013 (edited) i wouldn't have any concern at all just using sealant or the gap distance. a tiny fraction shouldn't affect it that much at all. these pumps/timing belt set up are robust and issues are almost unheard of so they should be very forgiving. hope that works. what a strange debacle. thousands upon thousands of these are done without issue...something odd is happening here. Edited December 23, 2013 by grossgary Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 23, 2013 Share Posted December 23, 2013 Gasket goo can be a problem when people use it on the oil pump, which is why Anaerobic sealant is the stuff to use. Cooling system is a different beast though. Big passages, and not many places for RTV to get stuck. Link to comment Share on other sites More sharing options...
Pierobon Posted December 26, 2013 Share Posted December 26, 2013 (edited) I guess it's a no-go. Tested and retested, engine idling leaks about 3 table spoons of glycol for every hour running. I'm tired and depressed about this situation. And now I discovered the steering oil pump js leaking too... My grand dad is probably gonna sell the car after this. =( Edited December 26, 2013 by Pierobon Link to comment Share on other sites More sharing options...
idosubaru Posted December 26, 2013 Share Posted December 26, 2013 On 12/26/2013 at 12:42 PM, Pierobon said: I guess it's a no-go. Tested and retested, engine idling leaks about 3 table spoons of glycol for every hour running. I it's not the seal/gasket area. I think you're trying to repair somethign that's not an issue. I would replace the water pump first if you can't find the issue. It may have a hairline crack or gap somewhere that's opening when thermal cycling and leaking. 1. The water pump has a casting flaw or crack, compromise in it 2. There's a casting flaw in the block Casting flaws can expand/contract with heat and leak only at high temps and be difficult to find. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 26, 2013 Share Posted December 26, 2013 the steering pump leak is likely the o-ring between the reservoir and the pump. it takes about 30 minutes to replace. Link to comment Share on other sites More sharing options...
Pierobon Posted December 27, 2013 Share Posted December 27, 2013 On 12/26/2013 at 2:22 PM, johnceggleston said: the steering pump leak is likely the o-ring between the reservoir and the pump. it takes about 30 minutes to replace. Problem is that I already replaced it, again original subaru part. Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2013 Share Posted December 27, 2013 power steering pumps have a shaft seal and rear gasket as well. there's a rebuild kit for them from Subaru. failure is very rare, rebuilds or used pumps are the alternative to the high cost of a new Subaru one. On 12/27/2013 at 6:01 PM, Pierobon said: Problem is that I already replaced it, again original subaru part. you got that oring from Subaru? i didn't even know they sold it here in the states!? Link to comment Share on other sites More sharing options...
Pierobon Posted December 27, 2013 Share Posted December 27, 2013 On 12/27/2013 at 6:15 PM, grossgary said: power steering pumps have a shaft seal and rear gasket as well. there's a rebuild kit for them from Subaru. failure is very rare, rebuilds or used pumps are the alternative to the high cost of a new Subaru one. you got that oring from Subaru? i didn't even know they sold it here in the states!? my problem has nothing to do with the power steering shaft or gasket. what's leaking is the o-ring in the bottom of the oil reservoir. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 27, 2013 Share Posted December 27, 2013 Quote my problem has nothing to do with the power steering shaft or gasket.what's leaking is the o-ring in the bottom of the oil reservoir. you must be the unluckiest subaru owner in the world. the only positive thing so far is that the head gaskets are ok. thank goodness for the reliable? ej22. first the water pump that will not seal. and now the steering pump that will not seal. unbelievable. i can understand why your frustration. i wish i could help more. . Link to comment Share on other sites More sharing options...
Pierobon Posted December 27, 2013 Share Posted December 27, 2013 Mine is EJ20, I'm gonna remove all covers, fire up the engine and look for the leak point with some camera or mirror or loupe or idk. I know it will be easy to find cause i'm using a very blue glycol in the system instead of just water. I'll post here when I have news. Thanks for everything anyways! Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2013 Share Posted December 27, 2013 removing everything to get a good look sounds like a great idea at this point. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 28, 2013 Share Posted December 28, 2013 Did you replace the seal washer inside the steering reservoir? They can leak there too. They also tend to leak around the case seal. But these steering pumps are really easy to rebuild. Gotta go with Gary on the coolant leak issue, the pump housing could be cracked. Link to comment Share on other sites More sharing options...
