Driving me nuts
Just replaced timing belts on my 89 GL EA82 followed the link on here, turn crank till 3 marks one cam up turn crank 180 other cam up turn till timing marks install dist adjust to 20deg
idles perfect but backfires and now power driving
Please Help:eek:
Edited by pepsiguy
wasn't my first thought but i bet Qman has your demon covered, so start there.
you pulled the distributor? if so, double, triple...more...check the alignment, they're easy to mess up and seem unclear sometimes.
i think you mean 360, which is what it should be, or i'm reading it wrong.
Did you mean you turned the CAM 180? If you only turn the crank 180...actually, I have no idea what would happen. Turn the CRANK 360, which will spin the first cam (assuming it started with the mark pointing up/lined up with the valve cover seam/timing belt cover notch) so it is pointing down, 180 degrees from where it was.
I just did this. When I put the belt over the tensioner it pulled the cam to the left one tooth. My bro said it was right, It wasnt. I ended up getting it right on the 3rd shot.
Make sure thy line up exactly, I looked through the hole in the cam pully and centered the valve cover gasket in it.
now all im waiting on is a petcock for my rad.
good luck
rechecked cam gears
Flywheel at three marks
left is at 12 oclock in line with the grove in the cover
Right is at 6 oclock position
turn flywheel 360 deg to three marks Again
now left at 6 oclock
and right is at 12 oclock
firing order was set 1,3,2,4
is it possible the valve lash is way off from last person to work on it
  • 2 weeks later...
