okie bill Posted September 12, 2011 Share Posted September 12, 2011 I guess everyone but me has something like this, but since it took me a good part of my day to reinvent the wheel I think I deserve a pat on the back:brow: Link to comment Share on other sites More sharing options...
Turbone Posted September 13, 2011 Share Posted September 13, 2011 Hopefully it wont shear off when you try and break a head bolt lose :-p Link to comment Share on other sites More sharing options...
okie bill Posted September 13, 2011 Author Share Posted September 13, 2011 Thanks for the heads up, although it hadn't occurred to me to use that to break things loose. I have other tools and BFH's for that. It did work well to apply 47 Ft. Lbs of torque exactly where I needed it. Bill Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 13, 2011 Share Posted September 13, 2011 Most of us just use a couple sockets under the rocker assembly bolts for extra clearance and we use the Fel-Pro HG's that don't require retorquing. GD Link to comment Share on other sites More sharing options...
okie bill Posted September 14, 2011 Author Share Posted September 14, 2011 GD Seems to be the difference between experiance and "the book". Do you mean that I can raise the rocker assembly up, run through the torque sequence, then remove the sockets and torque the rocker assembly down ? Not trying to be obnoxious. I learned in my time as a telephone tech. that the book is for 1st timers and part of being a good tech. is learning which parts I didn't have to follow exactly. Bill Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 15, 2011 Share Posted September 15, 2011 (edited) Sorry - I should have been more clear. What we do is simulate the rocker assembly using two sockets or a stack of nuts that is approximately the same height as the rocker assembly. Thus you torque the head without the rocker assembly in place. Then you remove the two bolts, take out the spacers, and install the rocker assembly and torque it. This is a perfectly acceptable procedure and many people (including myself) have used it without issue. Even Subaru reccomends loosening, lubricating, and retightening the head bolts/nuts after a run-in cycle using their head gaskets. The Fel-Pro's have proven very durable for the EA's and they specifically don't require a retorque so most of us use them instead. Thus using this installation procedure along with the HG's that don't require a retorque makes this tool basically obsolete. Also - I did make a reduced socket like that once - I did it to check that the Fel-Pro's indeed did not loosen, etc. I was unable to get any of the bolts/nuts to further tighten with my torque insturment set to the final value. GD Edited September 15, 2011 by GeneralDisorder Link to comment Share on other sites More sharing options...
okie bill Posted September 16, 2011 Author Share Posted September 16, 2011 Ah ha now I see, and my head gaskets are Felpro. So not only have I reinvented the wheel, but a wooden spoke buggy wheel. Link to comment Share on other sites More sharing options...
Subruise Posted September 16, 2011 Share Posted September 16, 2011 *pats on back anyway* nice weld man RV Link to comment Share on other sites More sharing options...
seikialice88 Posted December 3, 2011 Share Posted December 3, 2011 okie bill said: Thanks for the heads up, although it hadn't occurred to me to use that to break things loose. I have other tools and BFH's for that. It did work well to apply 47 Ft. Lbs of torque exactly where I needed it. Bill I also think so. __________________ watch movies online free Link to comment Share on other sites More sharing options...
PRND3L Posted December 3, 2011 Share Posted December 3, 2011 I took a socket and extension and made a tool just like this when i had to rebuild my EA82 a year or so ago, worked perfectly. Link to comment Share on other sites More sharing options...
Mugs Posted December 3, 2011 Share Posted December 3, 2011 Or you can just buy one off the Mac tool truck for 30 bucks...It is actually designated for Honda heads, but it works for any 14mm 12 point head bolt style. It more then likely won't work for on car head assembly, but it sure makes ease of out of engine bay head work. Then again I have the luxury of seeing the tool truck every week. Here's a pic....except its 10mm Pat on the back none the less. Link to comment Share on other sites More sharing options...
